2006 Cobalt SS makes 270 WHP!
Old Dec 21, 2005 | 01:12 PM
Bad GTP's Avatar
We finally got our hands on Rob’s new Cobalt SS for the first time last night, and let’s just say that we all had a little FUN.
After several hours of testing with different supercharger pulleys, fuel injector sizes and air/fuel adjustments, we were able to achieve 270 WHP on 92-octane pump gas, with 18” wheels and a complete exhaust system.
Current mods include:
- INTENSE modular supercharger hub with 2.80” pulley - $129.99 (part numbers LSJ-IMH-090 and LSJ-IMP-280)
- Lucas 42.5 pound/hour fuel injectors - $159.99 (part number LSJ-FIS-425-4)
- Casper’s fuel injector connectors - $29.99 (part number LSJ-CIC-012-4)
- MAF Translator - $179.99 (part number LJS-FTS-MAFT)
- Autolite 3922 spark plugs - $7.96 (part number LSJ-ASP-3922 x 4)
- Catalytic converter removed – N/A (not sure how important this is, since the stock converter seems to flow pretty well)
Total parts cost = $507.92
Hoosier Performance (central Indiana) or INTENSE-Racing (central Ohio) will install the above package in about two hours (excluding the catalytic converter removal) for an additional $150.00.
Here’s the dyno chart for our final tune:
Boost ranged from 14 to 17 psi, increasing linearly with engine speed all the way to the 6,500 RPM rev limiter. Quite a bit more horsepower should be available as soon as we get a good exhaust system installed.
Wide band air/fuel ratio for the final tune ranged from 11.3:1 to 12.7:1. The air/fuel curve is OK and safe, but certainly no where near as nice and powerful as we’ll be able to make it once we get access to the PCM code.
Peak horsepower was 270 WHP at 6,500 RPM. Peak torque was 237 WTQ in the 4,800 RPM range. Using the industry standard of 15% drivetrain loss for a FWD manual tranny, this works out to 317 horsepower and 279 foot-pounds of torque at the crankshaft. Very impressive for 2.0 liters of engine!
Side effects of the above combination include the following:
1. You’ll need a special tool to remove your stock supercharger pulley, and install the new modular hub.
2. You’ll want to invest in some sort of scan gauge to monitor KR and have a better understanding of everything when you run this much boost.
3. The fuel injector connectors (eight wires) and MAF Translator (6 wires) must be soldered in at this time. It will be a while longer before we’re able to source all the nice plug and play connectors required for these cars, but we’re working on these now.
4. Although the very cool stock hydraulic belt tensioner does a fine job of taking up the extra belt slack, the more correct way to do this would be with a smaller belt. We’re trying to source this now, and plan to have it available at some point in the future.
The most exciting thing for us is that there’s still TONS more potential in this little powerplant. Some of the next things we plan to address include the exhaust system, induction system, a machined supercharger snout to allow a smaller supercharger pulley, PCM tuning and a few other fun things.
Old Dec 21, 2005 | 01:16 PM
Hutnek's Avatar
wow....awesome
Old Dec 21, 2005 | 01:17 PM
chipsgt's Avatar
Wow! Very nice numbers!!!!!
JamesBrown's Avatar
*checks pants for moisture*
Old Dec 21, 2005 | 01:21 PM
kissmySS's Avatar
SIMPLY AMAZING.....!!!
Wow thats very very impressive Im speechless.....Great work! thanks for all that info i cant wait.. Merry Christmas Civic and SRT-4 Owners.....
Old Dec 21, 2005 | 01:22 PM
silverSS's Avatar
:jaw drops:
Old Dec 21, 2005 | 01:23 PM
astrocrep's Avatar
Thats AMAZING!!! So Happy to hear that... God... I really think we can break 300whp and soon!
-Rich
Old Dec 21, 2005 | 01:31 PM
FAST06SS's Avatar
All i can say now is that the car is a BEAST!!!! Anything less than 60mph results in wheelspin! 5th gear on the road at 75mph, floor it, w/o downshifting, it will set you back in the seat!
Look for more BIG news coming soon!
Thanks to INTENSE, and my racing buddies for thier help so far. Not like it took much work though
OniMirage's Avatar
-Rich
that is exactly what I was thinking
Old Dec 21, 2005 | 01:39 PM
astrocrep's Avatar
Hey,
Is the stock boost gauge reading 17lbs of boost?
-Rich
Old Dec 21, 2005 | 01:41 PM
FAST06SS's Avatar
Hey,
-Rich
I replaced my stock gauge with the Aeroforce gauge. Sorry.
Old Dec 21, 2005 | 01:47 PM
Rogue's Avatar
It was a great time working with this car. The best part of the night was canabalizing my car for 4 of its injectors to try in Rob's Cobalt. Nothing like swapping injectors in the dark and 12 degrees out
Great numbers Rob! I can only image what the drive home was like.
Old Dec 21, 2005 | 01:54 PM
DC52NV's Avatar
great #'s guys. keep up the good work.
Old Dec 21, 2005 | 01:56 PM
gonzo's Avatar
AWESOME
Old Dec 21, 2005 | 01:59 PM
RACIN_RANDY's Avatar
Nice!!!!!!! Can't Wait For A Bonus Check From Work
Old Dec 21, 2005 | 02:00 PM
memphisr24's Avatar
That's freaking awsome. Do you think that setup would work with the GM reflash?
Old Dec 21, 2005 | 02:01 PM
GTPMORAD's Avatar
Very impressive #'s guys!!
Sounds like there is alot of room for improvement once you have pcm access.
What are these cars weighing in at anyway? Sorry for the newb question
max_boost's Avatar
That's awesome, you guys aren't wasting any time.
Old Dec 21, 2005 | 02:11 PM
Bad GTP's Avatar
Yes. With the GM reflash, the MAF Translator wouldn't be required.
Old Dec 21, 2005 | 02:20 PM
denny's Avatar
Holy sh*t those are very impressive numbers. Cant wait for spring/summer!!
Old Dec 21, 2005 | 02:25 PM
Leafy's Avatar
That's pretty Awesome, Only 17psi and it's already netting pretty hefty numbers...
Old Dec 21, 2005 | 02:32 PM
BLKSS's Avatar
Right there with ya Denny
Old Dec 21, 2005 | 02:33 PM
Highhp's Avatar
Congrats Rob
Old Dec 21, 2005 | 02:46 PM
distillion's Avatar
hows the clutch?
Old Dec 21, 2005 | 02:48 PM
R33P3R007's Avatar
360 L337 User
Is there anyone that can do this closer to me. man Would that be sweet. As Soon as this is plug and play I guess I'll do it myself.
After stage reflash when it can be reversed easily. I'll be on it. I only want 300whp then I may stop.
How long would it take to install?
