2006 Saturn Redline Dyno Pull - 259HP
Also have you done a boost leak test?
the intercooler doesnt help either... its rather large lol.
Its ok Chris, I have faith in you, we can keep playing with the numbers, itll get there even if I have to blow sum N2O thru there lol.
l8r,
PD
I havent been able to find any boost leaks. when everything is apart in a few weeks Ill test that, do a leak down and compression test. clean up all of my piping, check my BOV and replace the gasket there and at the wastegate.
l8r,
PD
l8r,
PD
It should boost up faster soon!
Just an FYI I did a pull this morning with my new tune I want to give you and hit 18psi/36lb/min and hit 65% duty cylce on 100% E85. Previously my IDC was at 75-77%. I have the percentage it changes the fueling throughout the MAF and it should be a somewhat smooth transition. Car feels better when I drive. I also have a new timing MAP so we can increase your gas mileage a bit.
I love the sound of mine, I am glad I got the antisurge housing. Makes the whistle better even when I am not in boost.
I'm not sure what gear it was in. I think it might have been 3rd. I meant to ask but I forgot, it was a very hectic day.
And I'm HP Tuned by my boyfriend PD, his name on here is BlkWdoSS.
He dyno'd his turbo swapped LSJ and it made 438HP
Here's his video:
2006 Cobalt SS/SC (Turbo Swapped) - Dyno Pull 1 - YouTube
Here's his video:
the 2000rpm powerband was never the plan lol. as SCCobaltSS and I have been discussing, we are working on getting the turbo to spool faster. I have some mods that are going to change it, and also if the motor revved to 8200+rpm like the other cars that run the same turbo, It would have a much larger powerband and make a **** ton more power. I do not, I am running a COMPLETELY stock motor LSJ. No ported head, no turbo cams no extras that would increase flow and decrease spool time.
give me sum time, promise the next one will be better lolz
l8r,
PD
l8r,
PD
l8r,
PD
l8r,
PD
l8r,
PD
l8r,
PD
lol, i know, but sum ppl give me a lot of **** about it and so I typically explain what is going on with it. The Turbo is HUGE!!!
No not yet, Im off work all next week, so Im starting the tear down and wiring and **** this weekend. I picked up an LSD trans so that is also going into the car.
Im still impressed by you and Brian's numbers, both of yalls cars done extremely well.
l8r,
PD
l8r,
PD
Sep 28, 2015 12:51 PM
