2006 stage 3 problems help!
Hey guys i signed up for this one question; my air fuel ratio is so wako it bounces my idle is terrible bounces from almost a stall (an some times does ) to 1100 rpm and when you are driving if i push my pedal over 20% the afr drops to 9.9!! Not to mention that my afr’s are bouncing too anywhere from 11.5- 19.8 and everywhere in between I replaced my air filter wich was sevearly due for a new one and it made it worse i know i need a new tune but I figured before i spent alota money on a tune that might not even work , i would ask some experts and those who possibly had similar issues. Oh yes and there is no engine light currently one poped up and i deleted it (p0109) it stated high maf voltage i googled it and it didnt give me much
P0109 is intermittent MAP sensor circuit which looks like it means either your MAP sensor is faulty or the connection or wire is faulty. If your map sensor isn't working properly it can definitely cause your car to run funny.
