218hp/211tq on my setup? what happened!
Old Mar 26, 2011 | 04:43 PM
G11's Avatar
G11
not sure what happened! granted it was on a mustang dyno i will have to take a pic of the print out but ya! i was just shocked that it read that low!
Old Mar 26, 2011 | 04:49 PM
OBZ's Avatar
OBZ
Dude.. SCREW Ziptie.. That's not accurate..
Old Mar 26, 2011 | 04:51 PM
G11's Avatar
G11
ya but the previous dyno i got 203/184 but that was on a injen, 2.9, zzp midlength, and 42s
i just didn't get that!
alot of the evos got 250ish and i was way suprised!
Old Mar 26, 2011 | 04:53 PM
TommyP's Avatar
AWD > FWD
Gotta be in the tune if it's not a flaw in the dyno.
Old Mar 26, 2011 | 04:54 PM
OBZ's Avatar
OBZ
What were the corrected numbers?
Old Mar 26, 2011 | 05:03 PM
G11's Avatar
G11
those are the wcf's....
max power 191.5 @ 6521 rpm / 102.6 MPH
with wcf 218.6
max torque 185.3@ 4655 / 73.4 mph
with wcf 211.5
Old Mar 26, 2011 | 05:08 PM
OBZ's Avatar
OBZ
wcf???" I'm asking because when i dyno'd somewhere else then dyno'd there with no change in mods, the corrected numbers were almost identical to the other dyno.
Old Mar 26, 2011 | 05:10 PM
G11's Avatar
G11
well im not 100% sure then haha! that is all it says on the paper with the results
Old Mar 26, 2011 | 05:31 PM
ULWizSS's Avatar
my base GM3 run with a 2.9, zzp 3 catless, Injen was 233/190. Quick tweak by nick and i was at 243/199. Another tweak and it was 253/223. So i dont think its far off at all.
Wow did not notice you had all that done. IC Pump working alright?
Old Mar 26, 2011 | 05:34 PM
Black SS/SC 06's Avatar
Yea I would check your IC pump
Old Mar 26, 2011 | 05:40 PM
ebristol's Avatar
Your car hates you.
Old Mar 26, 2011 | 05:47 PM
G11's Avatar
G11
my pump works but i dont see how i would only have this increase with how much more i did! i mean i changed a lot of stuff and didn't see too much of a gain besides tq
Old Mar 26, 2011 | 05:50 PM
G11's Avatar
G11
almost want to see if i can get more out of my tune...i feel like it has more but vince says that it is good where it stands
Must be the tune then. You install those lights yet?
Old Mar 26, 2011 | 05:59 PM
G11's Avatar
G11
ya! love them! thanks man! just need hids in them i need to adjust my bumper a little...slight gap between the lights and the bumper
almost want to see what byt could do...
Old Mar 26, 2011 | 06:01 PM
Bluelightning's Avatar
Got Bewst?
Ouch, with all you have done you should be way higher than that. Something isn't right
Old Mar 26, 2011 | 06:02 PM
G11's Avatar
G11
i know that is y i was uber depressed! i saw ebristols numbers and compared mods and i should be right there with him in a sense... i mean i drove a 08 ss/tc yesterday and mine pulls so much harder than it did!
Old Mar 26, 2011 | 06:15 PM
Got Bewst?
Maybe go to a different dyno
Old Mar 26, 2011 | 06:23 PM
Yea you have to play with the fitment a little to get it right. I always had that problem with aftermarket lights on the balt.
G11's Avatar
G11
thinking so^^^
Old Mar 26, 2011 | 07:24 PM
Reaper06's Avatar
when you say vince do you mean a trifecta canned tune? Ive done 3 dyno sessions for just timming and afr adjustments on a 2.7 pulley and meth and pulled 287.4 out of it sooooo with what you have 295 would be locked down for sure. Do you have a interceptor
? seeing any kr? Iats shouldnt be a issue on E aslong as pump is working. hmmmmmm mabe some more old heads chime in. But I took some advice and just dumpd my money in tune time.
Old Mar 26, 2011 | 07:30 PM
G11's Avatar
G11
yes i have an interceptor and i haven't seen any knock and iats are awesome! specially with the griffin!
Old Mar 26, 2011 | 07:34 PM
Reaper06's Avatar
what is your timming at on ur interceptor? if you dont have a wideband do you know how to read o2 millivolts?
Old Mar 26, 2011 | 07:36 PM
Reaper06's Avatar
Dont bash me for saying this but I think youve spent way to much money to inturn get a tune from vince. Just me, not being mean or nutn just sayn your not a lnf which Ive herd only good things about vinces tune for them but you are a lsj on E so idk.
Old Mar 26, 2011 | 07:37 PM
G11's Avatar
G11
not sure i would have to look...wat would it be under? and i do have a wideband afr is good. i keep getting the stupid p1133 code tho even tho i changed my o2 sensor and i have no exhaust leaks
