27F and 2.9"=18psi... winter is upon us
Old Nov 3, 2006 | 10:04 AM
cds00bsmg's Avatar
Temps. are dropping low here. (Mid East Ohio). Cluster read 27F outside this morning, and it doesn't feel that much warmer at the moment.
Well, I was on my way to classes this morning, and I take this backwoods asshat route, so boosting and higher speeds is usually nill. That is, until my very brief stint on the highway for about a mile...
I decided "what the hell" and on the off ramp in 2nd opened it up. Boost gauge climbs right up to my usual 15, then right on past. I figure that when it hit around 17-18psi I should back out of it, and did so.
I don't have a wideband in the cabin, and have no idea what my AFRs are at. I'm probably being overly ****, but I'm in no position to blow my motor. My suggestion to everyone out there with any pulley/tuning modifications, would be to re-tune your car for winter (via HPTuners) as 06blackg85ss, and others have suggested. Just me 2 cents.
Just one more reason for me to swap back to the 3.1" for winter....
By the way, you can see from my "mods", that I'm running GM Stage 1. I'd imagine that Stage 1 or Stage 2, with a stock, or Stage 2 pulley would be alright for winter time. No way to really know until you get some sort of AFR readings though.
Old Nov 3, 2006 | 10:29 AM
RedlineBrian's Avatar
I have the GM stage flash. I plan on going to a 2.9 in. pulley. Do you guys think that is going to be a serious issue in the coming winter months on Long Island.
Old Nov 3, 2006 | 10:37 AM
Evilfrog's Avatar
I would get away to monitor AFRs. As soon as possiable.
Old Nov 3, 2006 | 11:29 AM
What about just regular stage 2 with the 3 in pulley? I cant afford a wideband.
Old Nov 3, 2006 | 03:53 PM
Rodimus_Prime's Avatar
gotta love winter!
Old Nov 3, 2006 | 04:08 PM
rickyw's Avatar
ive been hitting 15-16 psi stock but i am worried im going to blow something but its nice when i blow by some n/a cars
Old Nov 4, 2006 | 12:35 AM
NightriderCobaltSS's Avatar
it starting to get winter here i have a preatty much stock stage 2 hitting 16.5 PSI and my coollant usally hangs aroudn 185 now its around 172-176 .
Old Nov 4, 2006 | 02:26 AM
stotte20's Avatar
i have stage 2 with 2.79 pully and have had my car running like **** i even had a thread on it. about it missfiring up top in the rpm band. so i put my stage 2 pully back on and it is better until about the last 1000rpms then it stats to miss fire again
Old Nov 4, 2006 | 03:46 AM
Screamin!'s Avatar
I hit 17psi today on the stage 2 pulley! Can't wait to get the 2.79 on tomorrow.
Old Nov 4, 2006 | 08:02 AM
sammy's Avatar
you'll be running about 18.5 without a cat and 19~ with one
Old Nov 4, 2006 | 08:27 AM
zinner's Avatar
Moderator Alumni
Thats why you have a MAF/IAT sensor, it will tell the engine exactly how much air is getting into your motor, no matter what temp.
I am gonna do some data logs myself just to make sure.
Old Nov 4, 2006 | 08:39 AM
06' SS2SS's Avatar
5:40am here and 60*F. Raining like a MF out. I need the submarine mod they have for the Hummer.
Old Nov 4, 2006 | 08:50 AM
KillerNutz's Avatar
the car will be running more lean than your original tune. How much more is the question. I would find someway to log ur AFR to make sure. Its not uncommon for someone with an aggressive tune in the summer to be way to lean come winter time.
Old Nov 4, 2006 | 09:23 AM
zinner's Avatar
Moderator Alumni
Fueling is based on the MAF, the MAF measures the amount of air entering the engine in pounds of air an hour. If the air is cold it weights more. The computers and most importantly the engineers who built these systems know that.
Check and reset your fuel trims and see if they are different ...
Old Nov 4, 2006 | 11:33 AM
03gobluecobra's Avatar
If you can't afford a wideband, just go get a dyno. Only $75 or so.
Old Nov 4, 2006 | 04:05 PM
cds00bsmg's Avatar
The whole warning thing kind of went over your head huh? Conditions that are too lean are going to be fast to **** things up with your motor. Id keep your stock stage 2 on there for winter to be safe.
True, but you're still going to get boost spikes. As others have stated, those with an agressive spring/summer tune can/will be running lean during the winter. Ask 06blackg85ss about the few guys he knows who have blown motors so far because of the colder air temps.
BASICALLY, without anyway to monitor AFRs, you have no idea how lean/rich the car is running. Its going to run leaner the colder out it is, just because of air density, etc. Those with an agressive tune should check out their AFRs. Im just giving you all a heads up so you don't go leaning out and blowing it sky high...
Old Nov 4, 2006 | 05:07 PM
waitinforwar's Avatar
if the engine is running to lean or to rich the ckeck engine light should come one. that is partilly what your 02 sensor is for.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
Macgyver2484
Sep 23, 2015 11:36 PM
tamadrummer
Wheels and Tires
Sep 11, 2015 02:47 PM
