3 bar map
[QUOTE=Pedobear;5998735]i have this one i need to sell
GM Parts Direct: Your direct source for Genuine GM Parts
part number 12614973[/QUO
how much? and with pigtails?
ok can u put up a picture or 2? and just to confirm everything this is a 3 bar map sensor for the lsj and will fit right in? this is the one on top of the supercharger near the throttle body?
so this is the aeroforce one that will fit on the lsj moter and will work with my stage 3 kit?
AeroForce 3.5 Bar MAP Boost/Vacuum Sensor Kit [SENS022] : Lethal Performance, Performance parts for Ford Mustangs
does it look the same as the one pictured in that link you gave me? i dont think ive seen that one before
3 Bar MAP Sensor 55206797 - Crate Engine Depot
The LNF GMS1 sensor is ~3.3 bar.
If you have HP Tuners you can apply the following change to make it work:
Just to be sure you know though, your PCM can still only read up to 255kpa no matter what map sensor you use.
and yes thats a 2.5 i believe. if it is stock then it most likely is
I can get you a 3 bar TMAP that is a direct fit for the LSJ. Home ť Shop ť Sensors ť Pressure Sensors ť Bosch 3 Bar TMap Map Sensor with IAT
The only different size ones that go on the LSJ are the barometric pressure sensor and the supercharger inlet pressure sensor (the one on top of the S/C).
Why do you want a 3 bar sensor there??
Where exactly are you putting this sensor?
okay i have a little better understanding now, i originally thought that my supercharger inlet pressure sensor was my map-__- i did some research and found where my map is actually at and i am going to attempt to put on the 3 bar map i have. the map is the same one that Leafydialupking sent me the link to. i feel like an idiot but thanks for everything so far!
Wait...don't you have to change the linear/offset to match the sensor calibrations if you change maps?
Also I am confused.. Stage 3 bolt on kit? We are still talking SC right? If you are still SC then the stock 2.5bar sensor is fine(good to ~21psi right?). What is max boost you LSJ guys can push 17-19? Why go 3bar if you don't boost more than that? Your map is probably just bad, not inadequate.
