3 bar map
Old Aug 25, 2011 | 09:20 AM
Leafydialupking's Avatar
Originally Posted by hhrfreek
Ok...nm...I just noticed people can get 20psi+ w m62 on the lsj. Thats pretty crazy. I guess either way, do you know what your max pressure is?
The M62 really should never see over 15 psi since its efficiency drops so hard above that. I've also never really heard someone making that much, since its a bad thing. With a blower the less boost you make with the same pulley size the more power you make.
Old Aug 25, 2011 | 11:00 AM
hhrfreek's Avatar
Right on. I am only making ~10 on my 2.4l w/2.9"/exhaust.
It does seem possible on a 2.0l with stock exhaust, small pulley, maybe. But you are right that does sound like a bad thing regardless as I have read the same thing on efficiency.
https://www.cobaltss.net/forums/2-0l...t-ss-sc-33120/
I was thinking 18ish max until I read that.
Old Aug 25, 2011 | 07:16 PM
JCobalt's Avatar
I run 25 psi on the stock sensor with my tvs and have no problems at all. I'm not a tuner but I think ounce you go past the limit of the sensor your basically shooting in the dark and you just watch the afr and knock. I actualy have a 2.5 I'm about to put on which will give me a couple more pounds of boost. You should be able to tune with the stock sensor though.
Old Aug 31, 2011 | 11:47 PM
zrated89's Avatar
i just ordered mine from ballenger theyre lcal to me ill prolly see 25psi on my tvs and dont wanna shoot in the dark
Old Aug 31, 2011 | 11:49 PM
Dont forget to change the map sensor values to those in the paper work from ballenger.
Old Sep 1, 2011 | 07:48 AM
zrated89's Avatar
most def they send the values with it correct?
Old Sep 1, 2011 | 09:08 AM
It should be on the page you bought it on.
Old Sep 1, 2011 | 10:01 AM
zrated89's Avatar
seen it the sensors are physically the same right or do i need to pick up a pigtail?
Old Sep 3, 2011 | 09:55 AM
zrated89's Avatar
bump just to let folks know i got my tmap 3 bar from ballenger and fyi its the same exact part number from the crate engine depot site. If ced had listed it as a tmap and not just a map i could have saved 15 dollars just thought id share the info. And the 3 bar tmap i just got is a direct fit into my stock harness so lets lay that misconception to rest. The lsj can use the upgraded map for the lnf as well and can be bought from ced for cheap
Old Sep 3, 2011 | 09:56 AM
Yeah I didnt see that CED one until after you bought your, sorry. Also, those sensors are basically the same thing, why the **** is the 2.5 bar tmap so damn expensive?
Old Sep 3, 2011 | 10:00 AM
  #36
zrated89's Avatar
its stupid i see that in the automotive industry all the time. One part will be better and cost less the the oem part.
heres a pic same exact part number ced should change the description to a tmap sensor, because a lot of map sensors dont include the iat part
DarrenGC
Dec 24, 2021 01:55 PM
SSLOW06
Oct 1, 2015 07:21 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
