3 bar map
Old Aug 22, 2011 | 01:41 AM
Dshif7411's Avatar
3 bar map
Does anyone know where i can find a 3 bar map sensor? i have a bolt on stage 3 kit to my 07 ss/sc and blew my map.
thanks in advance.
Old Aug 22, 2011 | 01:43 AM
Pedobear's Avatar
i have this one i need to sell
http://www.gmpartsdirect.com/results.cfm
part number 12614973
Old Aug 22, 2011 | 04:25 AM
insylem's Avatar
Aeroforce sells them.
Old Aug 22, 2011 | 06:03 PM
Dshif7411's Avatar
[QUOTE=Pedobear;5998735]i have this one i need to sell
GM Parts Direct: Your direct source for Genuine GM Parts
part number 12614973[/QUO
how much? and with pigtails?
Old Aug 22, 2011 | 07:01 PM
Pedobear's Avatar
just the sensor... gmpartsdirect has them for 50 ill let it go for 35
Old Aug 22, 2011 | 10:09 PM
Dshif7411's Avatar
ok can u put up a picture or 2? and just to confirm everything this is a 3 bar map sensor for the lsj and will fit right in? this is the one on top of the supercharger near the throttle body?
Old Aug 22, 2011 | 10:36 PM
Dshif7411's Avatar
so this is the aeroforce one that will fit on the lsj moter and will work with my stage 3 kit?
AeroForce 3.5 Bar MAP Boost/Vacuum Sensor Kit [SENS022] : Lethal Performance, Performance parts for Ford Mustangs
Old Aug 22, 2011 | 10:54 PM
Pedobear's Avatar
just looking at that one they are not the same., ill post a pic anyways
Old Aug 22, 2011 | 10:58 PM
Dshif7411's Avatar
yeah i know what mine looks like but i cant figure out if the 3 bar looks the same or not
Old Aug 22, 2011 | 11:01 PM
Pedobear's Avatar
does it look the same as the one pictured in that link you gave me? i dont think ive seen that one before
Old Aug 22, 2011 | 11:05 PM
Pyros777's Avatar
Originally Posted by Dshif7411
Does anyone know where to get a 3 bar map for the lsj?
3 Bar MAP Sensor 55206797 - Crate Engine Depot
Originally Posted by Pyros777
The LNF GMS1 sensor is ~3.3 bar.
If you have HP Tuners you can apply the following change to make it work:
If you want to run it in your car just change your Linear value to 329.43750, and your Offset to -6.35156.
Just to be sure you know though, your PCM can still only read up to 255kpa no matter what map sensor you use.
Old Aug 22, 2011 | 11:07 PM
Pedobear's Avatar
then whats the one im trying to get rid of a 2.5 bar?
Old Aug 22, 2011 | 11:21 PM
Dshif7411's Avatar
that map is for the lnf. i already got one and it didnt fit. theres a different size for the lsj which is where im confused cause i cant find a 3 bar for that one.
and yes thats a 2.5 i believe. if it is stock then it most likely is
Old Aug 22, 2011 | 11:22 PM
Pedobear's Avatar
i dunno what it is, i bought it when i boosted my previous 2.2L never installed it. its probably a 2.5 bar then
Old Aug 22, 2011 | 11:28 PM
Dshif7411's Avatar
it is a stock 2.5 map sensor for the lsj engine. i might purchase it from u if i cannot find an answer for a better map for the lsj engine not the lnf engine!
Old Aug 22, 2011 | 11:31 PM
Pedobear's Avatar
ok, ill more than likely still have it as i dont have any other interest in it.
Old Aug 22, 2011 | 11:37 PM
Dshif7411's Avatar
okay
hhrfreek's Avatar
Why would you need a better map sensor? The 2.5bar should be fine. It reads to ~36.25 (21.75psi). R you boosting more than that with your m62...?
Old Aug 23, 2011 | 12:29 AM
Leafydialupking's Avatar
I can get you a 3 bar TMAP that is a direct fit for the LSJ. Home ť Shop ť Sensors ť Pressure Sensors ť Bosch 3 Bar TMap Map Sensor with IAT
Old Aug 23, 2011 | 12:38 AM
Pedobear's Avatar
he bought the 2.5 map sensor i had. ACDelco part from GM
Old Aug 23, 2011 | 01:12 AM
Pyros777's Avatar
I'm almost at a loss for words at this statement...
The only different size ones that go on the LSJ are the barometric pressure sensor and the supercharger inlet pressure sensor (the one on top of the S/C).
Why do you want a 3 bar sensor there??
Where exactly are you putting this sensor?
Old Aug 24, 2011 | 10:48 PM
Dshif7411's Avatar
cause my boost is to high and it blew my old one. is the supercharger inlet pressure sensor different from the map? idk im so confused right now, not even gonna lie.
Old Aug 24, 2011 | 11:24 PM
Dshif7411's Avatar
okay i have a little better understanding now, i originally thought that my supercharger inlet pressure sensor was my map-__- i did some research and found where my map is actually at and i am going to attempt to put on the 3 bar map i have. the map is the same one that Leafydialupking sent me the link to. i feel like an idiot but thanks for everything so far!
Old Aug 25, 2011 | 07:45 AM
hhrfreek's Avatar
Wait...don't you have to change the linear/offset to match the sensor calibrations if you change maps?
Also I am confused.. Stage 3 bolt on kit? We are still talking SC right? If you are still SC then the stock 2.5bar sensor is fine(good to ~21psi right?). What is max boost you LSJ guys can push 17-19? Why go 3bar if you don't boost more than that? Your map is probably just bad, not inadequate.
Old Aug 25, 2011 | 07:51 AM
hhrfreek's Avatar
Ok...nm...I just noticed people can get 20psi+ w m62 on the lsj. Thats pretty crazy. I guess either way, do you know what your max pressure is?
