3 psi?
Old Jan 18, 2011 | 08:16 PM
Leafydialupking's Avatar
Is you belt slipping? Are you having a boost leak. These tests now take two people thanks to electronic throttle bodies.
Old Jan 18, 2011 | 08:27 PM
DoMiStIc_RuSh_06's Avatar
The belt has to be slipping or there's a leak. Could also be the valve itself. If you have codes, you should get them checked.
Old Jan 18, 2011 | 09:15 PM
HyperMuffin's Avatar
Pull your fuel rail and check all the orings on the end of the injectors and check the o-ring that is on the outside of the little "cups" that the injectors sit in. I had one of the o-rings on the outside of those little cups somehow break and was creating a massive vacuum leak.
Old Jan 18, 2011 | 09:21 PM
mrbelvedere's Avatar
yea u pluged the wrong one you need to plug the line coming from the intake to the bypass solenoid
Old Jan 18, 2011 | 10:39 PM
boost_junkie16's Avatar
My bad
Old Jan 19, 2011 | 01:19 AM
by plugging the one from the intake it will show if the bypass solenoid is bad or not
Old Jan 19, 2011 | 01:22 AM
I've got my headlights out painting eyelids atm so unfortunately testing it is a no-go until tomorrow afternoon sometime
Old Jan 19, 2011 | 03:33 PM
Plugged it and still nothing. Going to order new gaskets and pull the SC off once I get them.
Old Jan 19, 2011 | 04:38 PM
reach undr the bypass valve and try to move it see if it moves free it could be stuck
Could it have something to do with where you just went catless...maybe that code it's getting is causing your at to go into limp mode.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
