3" pulley installed; WOW!
Old Mar 16, 2006 | 05:55 AM
bigjoe25's Avatar
Originally Posted by nick11
dude thats horrible I am doing 14.4 with my car STOCK .... do you know have the lsd package or something?
no i dont have the lsd it is that i dont have much seat time also the track prep where i go sucks i will get better over the summer also if you have ant tips i would love to hear them
Old Mar 16, 2006 | 06:34 AM
tube's Avatar
Powershift, powershift, powershift. When I powershift it cuts a half second off my time. Just don't remove your foot from the gas pedal the entire run, shift with it to the floor, tap the clutch and JAM it into gear.
Old Mar 16, 2006 | 07:37 AM
BLKSS's Avatar
You boost should be shutting down shortly after 6000. I would consider doing the boost bypass but not for daily driving. Keep it for the track.
Old Mar 16, 2006 | 07:55 AM
Darksun's Avatar
I think someones cat is getting owned and they don't know it.
Old Mar 16, 2006 | 08:18 AM
Shortbus's Avatar
Thats a wonderfull way to go through many clutches.
Old Mar 16, 2006 | 08:30 AM
c7015's Avatar
I think he is talking about his track time not his boost level
Old Mar 16, 2006 | 09:47 AM
Ljavy17's Avatar
Oh Lmao, I Get It Now.
Old Mar 16, 2006 | 10:04 AM
djt81185's Avatar
Originally Posted by Mines_Better
the blower will scream when you put it on. my 3" pulley puts my boost up at 15.5psi and i dont have the bypass mod either. nor does it drop down at higher RPM's, it stays up there all the way to 6000rpm.
You think it screams with a 3.0 you should try a 2.7"...if u floor it next to a jersey barrier with the window down you think your ear drums are gonna blow out...its awesome
Old Mar 16, 2006 | 09:51 PM
tube's Avatar
Actually, powershifting is a good way to go through synchronizers... but anyway.
BOOST.
Old Mar 16, 2006 | 10:00 PM
SilverSS/SC's Avatar
Nice to hear the good results . Im doing a 3" pulley this month and get the best out of it until the PCM can be cracked . Then I'll go bigger ....errrr smaller , I dont want to mess with piggybacks or a MafT .
Old Mar 17, 2006 | 04:44 AM
  #36
Brian MP5T's Avatar
Not Helpful really... It's been documented and discussed at great lenghts that the stock clutch is weak and fill fail very quickly if abused.
Old Mar 17, 2006 | 06:34 AM
  #37
tube's Avatar
Powershifting doesn't damage the clutch; it damages the synchronizers.
Old Mar 17, 2006 | 07:53 AM
  #38
djt81185's Avatar
Brian is right it damages your clutch...technically anything but double clutching "ruins" synchros. but in this case you keep the gas to the floor and the revs stay pinned. You push clutch in tranny input shaft and clutch disc start to slow. Synchros synchronize next gear with input shaft that is already spinning faster so now the tranny is ready for the next gear all at the same speed but the engine is reved out but due to rpm drop at same speed in higher gear the tranny is going to be slower. Guess what absorbs the extra revs to synchronize the tranny and motor...the clutch. The potential is there that youll be feading too much torque and the disc will slip instead of grabbing...if i power shifted my neon on nitrous the clutch would spin. If i completed the shift before going WOT again i'd have no problems
Dan
Old Mar 17, 2006 | 08:54 AM
  #39
Brian MP5T's Avatar
Ummm,
Burning The Clutch with friction? That somehow does not damage the disk? Physically Impossible and Incorrect.
Heat will warp the flywheel as well if it builds up after several passes.
Old Apr 1, 2006 | 08:09 PM
  #40
bigjoe25's Avatar
ok i just got back from the dyno and i am not happy it was my first time at this dyno it was a dyno jet i only put down 217.6hp and 190.9tq the last dyno i went to before the 3in pulley i put down 220hp and 192tq it was a dynapack i dont know why it was so much lower this time if any body can shed some light on this for me it would be helpfull(also i had the boost by pass done)
Old Apr 1, 2006 | 08:13 PM
  #41
Jmc007's Avatar
bigjoe what are your other mods, which year is your car ?
Old Apr 1, 2006 | 08:19 PM
  #42
bigjoe25's Avatar
the only outher thing is the air filter mod and it is an 05 ss/sc
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
