30 psi boost gauge problem! HELP HELP HELP
Old Feb 28, 2009 | 10:51 AM
ajm5036's Avatar
I have an 06 SS/SC and I installed the SS/TC 30 psi gauge in it. I read on here that it was just plug and play and would allow me to read up to 22.25 psi. But it automatically reads really high. As if the needle is just moving to the same spot as it would on the 20 psi gauge. So where I would usually buust 17 or 18 psi it will read as 26 or 27 psi on the 30 psi guage. Is there a way to calibrate the boost gauge reading? What is the problem here? The gauge works fine but the reading is off. Does anyone know that can help me out?
Old Feb 28, 2009 | 10:54 AM
ls1fbody's Avatar
Haz l33t wheelz.
interesting...
Old Feb 28, 2009 | 10:57 AM
Silver Bullet's Avatar
If the two gauges have the same range of sweep, you will probly need a boost sensor that goes up to 30 psi to make it work right.
Old Feb 28, 2009 | 11:09 AM
ajm5036's Avatar
WHat do you mean by boost sensor? Is that an actual part or are you being theoretical? Because I'm looking for a real world solution, like what is the problem and what part or what type of tuning change would make this work? Specifically. Does anyone have any idea?
Bump for an answer
Anyone have any clue on this?
Old Mar 1, 2009 | 10:46 AM
ajm5036's Avatar
Old Mar 2, 2009 | 08:07 PM
ajm5036's Avatar
Old Mar 2, 2009 | 08:37 PM
Matt M's Avatar
Most GM MAP sensors operate over the same voltage range. This means that switching from a 1 bar MAP to a 2 bar MAP requires ECM changes to designate the correct vacuum/boost reading based on MAP sensor voltage. The problem you are having is similar. Since both boost gauges have a 0-5volt sweep, both gauges will max at the same boost level unless you switch to the correct corresponding MAP sensor with the 30psi gauge. Unfortunately, this will also require an ECM change to keep the tune accurate.
Old Mar 2, 2009 | 09:08 PM
wtpcobaltss's Avatar
^^^^ exactly what he said. ull never see 30 psi on our blowers anyway.
Old Mar 3, 2009 | 12:51 AM
Dainslaif's Avatar
Matt is absolutely correct - when it comes to these electrical boost gauges, 0v = min boost, 5v = max boost, regardless of what the gauge range is.
Old Mar 3, 2009 | 01:01 AM
SS/SCking's Avatar
What has the 2 bar MAP? or were do I get it?
Old Mar 3, 2009 | 12:42 PM
Matt M's Avatar
In the case of installing a TC boost gauge in an SC, you are switching from a 2.5 bar MAP to a 3 bar MAP. I just used 1 and 2 bar as an example.
Old Mar 3, 2009 | 03:02 PM
SS/SCking's Avatar
Oh Ok than where do I get the 3 bar map?
Old Mar 3, 2009 | 07:12 PM
red06SC's Avatar
just put your 20psi back on or get an aftermarket
looks like you're going to pay out the ass for an OEM 30
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
