42lb injectors and stg 2 pulley stock
Old Mar 6, 2012 | 08:39 PM
Blinker fluid's Avatar
Hey guys, I found 42lb. injectors, and a zzp stage 2 pulley on craigslist. Are their any more supporting mods I need to run these things? There is also a stage 3 heat exchanger the guy has...I dont know if I could run that? Would it help? I guess im just confused on what I can and can not do....He also has 60lb injectors, but I probably want the 42lb right? This is all on a stock tuned 2.0lsj
EDIT: I would like to add that all of this came off a redline...if that makes a difference
Old Mar 6, 2012 | 09:03 PM
Vander Nars's Avatar
Lol the troll is strong with this one.
Old Mar 6, 2012 | 09:11 PM
huh?..i am just looking for simple answers, i dont really know a lot about this stuff yet..
Old Mar 6, 2012 | 10:28 PM
Proinmaster's Avatar
pretty sure the redline pulley is the same since its a m62 supercharger. typically 2.8 pulleys are ran with 60 lb injectors. A stage 3 heat exchanger if you have the extra cash always is a good idea because it lowers air intake temperatures. Running these you would need a tune. you can get a canned tune that would be better then nothing but a tune specific for your car is always. i would spend the extra money and get it tuned by a shop. Hope this helps. you can send a pm my way if you have other questions, i might be able to help you out
Old Mar 6, 2012 | 11:51 PM
ULWizSS's Avatar
No you you will be fine. You will need a HE around 2.8 pulley. And you will need someone to change your tune.
Old Mar 8, 2012 | 12:13 PM
thankyou for the helpful advice!!!
Old Mar 8, 2012 | 12:30 PM
574's Avatar
574
Buy the h/e used so when you mod later down the road with a smaller pulley you'll have it and won't have to buy a new one.... same goes for the 60's. ****** that **** up. If nothing else you could sell them on here
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
