5 Pin Relay Switch with Connector
Hey Guys, I got 5 Pin Relay Switch with Connector. I am gonna do wiring up for Wideband to A/C pressure sensor. I am seeing that I have 5 colors it's Black, Red, Blue, Green, and Yellow. I want to know is that right Red is Positive and Black is Negative ? What about Blue, Green, and Yellow ? I have Rocker Switch too for switch back and forth. Help Me Out Here, Thanks
Yep! I hope this is Right ? But I am gonna switch Black and Yellow from the Connector that I got from EBay.
Found the Answer!
85- 12v Rocker Switch- Black
86- Ground- Yellow
87a- A/C Pressure Sensor- Green
87- Wideband- Blue
30- To PCM- Red
I got 5 Pin Relay Switch and Connector from EBay. That's why Colors that are connected are different.
Found the Answer!
86- Ground- Yellow
87- Wideband- Blue
30- To PCM- Red
Anybody!? Do any 1 know how to hook that up ? Do You have to install everything like wired up everything to get Rocker Switch On or Rocker Switch could be turned on with just + n - Wires ?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
