50 shot of NOS ok with stage 3 ?
Old Jul 11, 2011 | 04:37 AM
kstorm61's Avatar
ok so i did some looking around and keep finding mixed reviews on things. Anyone run a wet 50 shot with these mods and not have a damaged engine ?
I want to run a kit that only comes on at wide open throttle and cuts off if i miss a gear or not when im just daily driving. Any ideas on where to get a kit from ?
this is the only kit is 400 and also a 600 dollar one i found it all comes down to good selionods is what i have been told
http://www.modernperformance.com/nit...ne-p-2118.html
60lb injectors
zzp midlength header
3inch dp
2.9 pulley
stage 2 belt
wide ban guage
15psi
zzp can tune
bkr73 spark plugs
s3 heat exchanger
dual pass end plate
an does a 50 shot = 50hp to the crank an figure in a 10-15% drive train loss ?
Old Jul 11, 2011 | 05:51 AM
Erick161's Avatar
blazin had said he ran it with no problems. if you take precautions, I'd presume you'd be ok. and yes, usually a 50 shot translates to around 45whp, 75shot around 65-70whp.
Old Jul 11, 2011 | 05:59 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
You have to be careful running it with a stage kit from one of those vendors though. It would be wise to get tuned specifically for it.
On a GM tune, that's a different story. 50 shots are usually not something to worry about... but with the added timing that comes with some of those canned tunes... i'd be cautious.
Old Jul 11, 2011 | 07:17 AM
Staged07SS's Avatar
Administrator
Administrator
The GMR Stage 3 kit is set up for a 50 shot, and is very safe.
The kit you have listed is not a "Stage 3" kit, and will be best if you get it custom tuned for the mods & shot of nitrous.
Old Jul 11, 2011 | 12:17 PM
ebristol's Avatar
When your baby screams and whines give it the bottle...Nitrous Trifecta GMS3 - Saturn ION RedLine Forums
Old Jul 11, 2011 | 02:48 PM
kstorm61's Avatar
Thanks for the replies everyone. Also Ebristol is going to be doing my tune
Old Jul 11, 2011 | 03:46 PM
red06SC's Avatar
I need "NOS", two bottles, the big ones.
frigging F&F single handedly turned a brand called N.O.S. in to a substitute word for nitrous
Old Jul 11, 2011 | 08:04 PM
kstorm61's Avatar
im just trying to figure out if its worth it. i only want it for the track to get a little edge. I dont want to spend the money if i cant run it safely
Old Jul 12, 2011 | 12:23 PM
Dynamico's Avatar
It can take it... I am running a 75 shot with about the same mods as u but instead at 19 psi with a 2.8. Also u didn't mention any intake mod but I hope u got it. I have ran a couple of times with n2o and the lowest my wideband gets to is 11.2 So I think u should be more then safe with a good tune. Good Luck.
Old Jul 12, 2011 | 02:06 PM
kstorm61's Avatar
Thanks D Ya i have an intake. So im hopeing to make some good power. i dont know if a 3 or 50 would make much difference. I hope so. thats for the real answer
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
