50 shot of NOS ok with stage 3 ?
ok so i did some looking around and keep finding mixed reviews on things. Anyone run a wet 50 shot with these mods and not have a damaged engine ?
I want to run a kit that only comes on at wide open throttle and cuts off if i miss a gear or not when im just daily driving. Any ideas on where to get a kit from ?
this is the only kit is 400 and also a 600 dollar one i found it all comes down to good selionods is what i have been told
http://www.modernperformance.com/nit...ne-p-2118.html
60lb injectors
zzp midlength header
3inch dp
2.9 pulley
stage 2 belt
wide ban guage
15psi
zzp can tune
bkr73 spark plugs
s3 heat exchanger
dual pass end plate
an does a 50 shot = 50hp to the crank an figure in a 10-15% drive train loss ?
60lb injectors
3inch dp
2.9 pulley
stage 2 belt
wide ban guage
15psi
zzp can tune
bkr73 spark plugs
s3 heat exchanger
dual pass end plate
You have to be careful running it with a stage kit from one of those vendors though. It would be wise to get tuned specifically for it.
On a GM tune, that's a different story. 50 shots are usually not something to worry about... but with the added timing that comes with some of those canned tunes... i'd be cautious.
The GMR Stage 3 kit is set up for a 50 shot, and is very safe.
The kit you have listed is not a "Stage 3" kit, and will be best if you get it custom tuned for the mods & shot of nitrous.
It can take it... I am running a 75 shot with about the same mods as u but instead at 19 psi with a 2.8. Also u didn't mention any intake mod but I hope u got it. I have ran a couple of times with n2o and the lowest my wideband gets to is 11.2 So I think u should be more then safe with a good tune. Good Luck.
thats for the real answer
