60lbers with 2.7
Old Jan 31, 2010 | 06:52 PM
utibalt's Avatar
60lbers with 2.7
I'm going to be getting some 60lbers with 2.7" pulley, also adding a meth kit. besides another tune for the injectors/meth, what other supporting mods would i need? Look in signature for current mods. thanks for your help.
2005 Cobalt SS/SC
ps. i have 1 step colder plugs
Old Jan 31, 2010 | 06:57 PM
im gonna be going to 2.8 and 60s soon too
im gonna get new spark plugs, stage 2 belt, bigger intercooler/heat exchanger(same thing), wideband gauge, oh a hub for the smaller pulley unless u got a different hub for the 3.0 pulley
since u gonna run meth thats a great cooling mod
Old Jan 31, 2010 | 08:30 PM
Supercharged Guy's Avatar
Heat Exchanger, Dual Pass, Option B, Good Tune and you should be good to go
Old Jan 31, 2010 | 08:40 PM
utibalt's Avatar
stock axles, heard i should have them replaced? how much horse can the stock axles handle? and i also heard meth injection should be the only cooling mod i should need. do i really need stuff listed below?
Old Jan 31, 2010 | 10:43 PM
Fonzi1289's Avatar
Yeah those r very good things to have!
Meth Helps but the other u would only benefit from
Old Jan 31, 2010 | 10:46 PM
meth would probably do the job but for added insurance i would do option b and larger fmhe. its like dating a hot girl. if shes got big **** and a tight ass it only gets better
Old Jan 31, 2010 | 10:53 PM
ssyellowss's Avatar
the stock axles will be fine unless you beat on them at the track. i'm on a 2.7/60 lb injectors without meth. i run a front mount heat exchanger for cooling and a 70% water/30% coolant in the intercooler system. enough to stave of freezing the water, but more water for better heat dissipation. on a hard WOT run from a stop to 4th gear my IAT2 temps dont top 130F. obviously the more cooling the better, so load up on cooling mods. highly recommend the heat exchanger, the meth is a big help, and dual pass endplate should find its way on your list. also a light porting of the supercharger could help keep temps down by increasing the efficiency of the supercharger.
Old Jan 31, 2010 | 11:37 PM
utibalt's Avatar
alright kool after i get the meth next step I'll go with the dual pass, then water cooler, last option b. any more input from people?
Old Jan 31, 2010 | 11:57 PM
make that bitch whine
Old Feb 1, 2010 | 12:32 AM
brownbandit9's Avatar
get a front mount too...that with meth will be plenty of cooling
Old Feb 1, 2010 | 01:51 PM
Zach06CobaltSC's Avatar
2.7, 60lbers, ngk bkr7e spark plugs, stage 2 belt, the meth kit I told you about *working on exact price* and you will be set.
You eventually can grab a dual pass with overflow or option b tank and or a front mount, but the meth is the first step.
After that in all honesty I would work on suspension mods.
Old Feb 1, 2010 | 02:35 PM
After that in all honesty I would port the head and then work on suspension mods.
fixed
Old Feb 2, 2010 | 06:20 AM
If you are wanting to put down some REAL numbers, he actually has a point. Porting the head would be a great idea, I have a spare head that sean can port for you/us too . Between the three of us, mainly you and sean we could knock out the swap in a day.
Old Feb 2, 2010 | 12:06 PM
if you port the head its done once and thats it, not like meth where you have to check and maintain proper fluid
Old Feb 2, 2010 | 03:58 PM
utibalt's Avatar
i do eventually want to build up a head, not sure if it'll happen this year. when i do build one up i'm gonna go all out though. might as well get the short block build up with it when i get it done.
Old Feb 10, 2010 | 10:25 PM
utibalt's Avatar
Well i'm all set, i have the injectors/harness, 2.7" pulley, meth kit, ZZP S3 heat exchanger, dual pass. Got an option b tank but traded it for the spacer i needed so the meth can inject itself..also bought a wideband for a more accurate tune. hopefully going to get everything installed this weekend, going to start on wideband and meth kit friday morning, should have it mostly set up, getting dual pass saturday, might not install til sunday, saturday going to put in the injectors and pulley, also get a tune... so hopefully by monday i should be good to go.. did i forget anything?
Old Feb 12, 2010 | 05:20 AM
Looks good patrick, can't wait to get this done bro.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Builttss
Oct 4, 2015 10:21 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
Builttss
Sep 22, 2015 12:42 AM
06lsj_justin
Sep 13, 2015 09:53 PM
