Is this the..?
Old Aug 17, 2008 | 02:50 PM
Perfect.disguise's Avatar
Is this the..?
Installed a header/downpipe and ordered a new header gasket.Well I'm on a tight schedule and the new gasket didn't come in by the time I installed it (ehh came in about a hr after I finished) Anyways I cranked it up and behind the block in the header area started smoking alittle..Nothing was touching as far as lines and whatnot so it had to be the exhaust.I let it sit a min and it isn't nearly as bad.At first I heard a leaking "ticking" sound but after it warmed up it stopped but it is still slightly "smoking".Well my question is that is just probably a leaky gasket right?
Old Aug 17, 2008 | 02:55 PM
Sharkey's Avatar
the smoking will be from your bare hands touching it during install. the oils in your hands get on the header and burn off creating the smoke. take it for a drive, you will know if you have a leak.
Old Aug 17, 2008 | 03:05 PM
ShortStack's Avatar
mine smoked too... its not a leak, you normally tell those by a crazy ass loud noise...
Old Aug 17, 2008 | 03:06 PM
Oh really? I didn't know that.
Someone also told me it could be from the carbon deposits being broken up. IDK.
I also couldn't get the top left stud in so I'm going to get a shop to do it(each primary has three bolts holding it down though).I reved it a few times once it got warmed up and I didn't hear a leak.I haven't driven it though.
How much?How long did it last?
Last edited by Perfect.disguise; Aug 17, 2008 at 03:06 PM. Reason: Automerged Doublepost
Old Aug 17, 2008 | 04:01 PM
ShortStack's Avatar
It was very noticable, went away after about 20 min of driving but i can still smell it a little bit.
Old Aug 17, 2008 | 04:43 PM
Like I said the left top stud isn't in. Will it be ok like that for a little while?Every primary has 3 bolts..the other side doesn't even have the hole..It's above that little tube.I don't hear a leak.I was just weary about the smoke because I didn't know if it was normal.
Old Aug 17, 2008 | 07:06 PM
Try2k's Avatar
I had a hard time with top left also... I got it as tight as I could, not nearly tight enough for my liking, but its been fine.
If you continue to hear the ticking it might be leaking until it heats up.
Old Aug 17, 2008 | 07:08 PM
Should I even worry about that stud?
Bass_Waves
Nov 23, 2013 08:07 PM
RebelPerformance
Apr 18, 2007 11:37 PM
torrin1234
Sep 24, 2006 11:01 PM
