About Installing A Tach
Old Aug 21, 2007 | 03:13 PM
sick_ss/sc's Avatar
does anyone know anything about installing a tach? there are 4 wires black, red, green, and yellow thanks
Old Aug 21, 2007 | 03:16 PM
07SSCharged248's Avatar
what kind of tach... Pics... Whynot just use a shift light
Old Aug 21, 2007 | 03:19 PM
Rangerondubz's Avatar
Probably b/c our tach is slow in 1st & 2nd, I could understand why he would do it but I wouldnt b/c I dont like the look, just put a shift light on that beast and be done w/ it. The shift light isnt going to be slow....
Old Aug 21, 2007 | 03:46 PM
sick_ss/sc's Avatar
i will take pics later. but i just dont know where to put the yello and green wire so any help would be helpful thanks guys
Old Aug 21, 2007 | 03:52 PM
SCcobaltSS's Avatar
What kind is it? Usually the tach is hooked up to ground, coil, and power. Instructions should tell you what the fourth is or, if its needed. I think the fourth will depend on how many cylinders you have... What have you already hooked up?
Old Aug 21, 2007 | 04:01 PM
06_SS_S/C's Avatar
Red and black are probably +12v switched and ground. Green is probably signal from coil and yellow is probably +12v switched for lighting. I'm just guessing here without any more info.
Old Aug 21, 2007 | 04:02 PM
sick_ss/sc's Avatar
i actually havent hooked up anything yet i wanted some advice before even touching it. been sitting in my room for 3 months tired of looking at it. its one off of glowshift.com it has 7 different colors. cant be that damn hard .thanks
Old Aug 21, 2007 | 04:03 PM
06_SS_S/C's Avatar
For hooking up the signal wire for the tach, check out this thread:
https://www.cobaltss.net/forums/show...ghlight=raptor
It's for installing a shift light, but the signal wire should be the same.
Old Aug 21, 2007 | 06:34 PM
rickay726's Avatar
rice just get a shift light the built in tachometer should be fine
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
