? about timing my cobaltSS
Old Nov 25, 2009 | 04:44 PM
harryresh's Avatar
alright...i just got done installing my forged pistons and putting my head back on. im ready to time it. i have my #1 cylinder (passenger side) @ TDC. now, once i have my cam gears back on, do i line the blue chain link with the intake mark on the intake cam gear and the red link should line up with the exhaust mark on the exhaust cam gear? making sure that bot valves are closed on the #1 cylinder?
Old Nov 25, 2009 | 05:02 PM
elite_Cyborg's Avatar
Here
Old Nov 25, 2009 | 05:05 PM
shaunmcdee's Avatar
Basically.
Intake - Blue link should be roughly at the 2 o'clock position pointing at the "INT" marking on the gear
Exhaust - Red link should be at roughly the 10 o'clock position pointing at the "EXH" making on the gear
The crank gear should be pointing at the 5 o'clock position, and thats where your purple link goes.
Simple stuff, good luck
Old Nov 26, 2009 | 12:29 AM
RednBlack's Avatar
Originally Posted by shaunmcdee
Basically.
simple as this I just did a hg replacement.
Old Nov 26, 2009 | 07:18 AM
harryresh's Avatar
thanks guys. i dont know how easy its gonna be to see the crank gear cuz i never took the engine out of the car lol.
Old Nov 26, 2009 | 11:21 AM
RednBlack's Avatar
take off the passenger side rim and plastic wheel well covering. you will have a perfect view of it.
Old Nov 26, 2009 | 12:22 PM
YzRider452's Avatar
Lemme know how you do this, I had a hard time timing my old cobalt when i had to replace #4 piston, I couldnt see the crank gear. This was the only thing stopping me from doing this this winter.
Old Nov 26, 2009 | 01:49 PM
shaunmcdee's Avatar
Lift car on passenger side
Take off rim
Take of plastic wheel well (should be like 1 or 2 8mm screws, the rest are just plastic body
clips
Take off crank pulley, its 1 bolt, then you just wrestle to get it off.
Take off idler pulley (you will have access thru the wheel well)
Take off side cover
Thats it. The hardest part for me was the crank pulley, they dont come off very easy.
The idler pulley is 1 bolt if memory serves me correct, use common sense and youll get it out.
The side cover bolts are a little tight, but if my fat hands can get to it, Im sure someone whos fingers that dont resemble sausages will have no trouble.
Take your time, these motors are pretty basic. Good luck
Old Nov 26, 2009 | 02:15 PM
harryresh's Avatar
earlier i popped of my cam sensor b/c i thought it was something else. does that mess my timing up? what do i do if it does?
thanks guys
Old Nov 26, 2009 | 02:54 PM
YzRider452's Avatar
You'll throw a code without it. Not sure if it will actually cause any damage tho.
Old Nov 26, 2009 | 05:14 PM
harryresh's Avatar
i put it right back on. what im saying is if, lets say i spun it 180 degrees and put it back in. will it mess it up? btw i got done timing my cobalt!
Old Nov 26, 2009 | 06:28 PM
YzRider452's Avatar
Did eveything turn out good? you fire it up yet? any timing codes?
Old Nov 27, 2009 | 04:01 PM
harryresh's Avatar
i didnt get all of it back together yet. i think my timing chain tensioner is messed up. i can make it collapse but gets tight towards the bottom of its stroke and doesnt pop out when i install it. You have to turn the engine over and make sure your cams are timed with your crank correctly after you time it the first time! the first time i timed it, the #1 cylinder was going down while the exhaust valves were opening. i had to remove the chain, spin the crank 360 degrees while not turning the cams, line all the marks up again, and everything was fine after that. also, be careful that your not turning your valves down into your pistons b/c your valves will hit your piston if your piston is @ TDC or close to TDC.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
roth
Sep 26, 2015 12:16 PM
