ABS light on help
Old Jan 30, 2011 | 11:51 AM
YEW FAIL's Avatar
ABS light on help
hey, i alrdy tried a search but couldnt really find what i was looking for. anyway last night i got a "ding" noise and my ABS light came on. i dont feel any difference in braking or anything, anyone have any idea what it could be?
Old Jan 30, 2011 | 12:11 PM
rnjmur's Avatar
It could be alot of things, you need to get the codes pulled to see if it is spitting one out (which it should be).
Old Jan 30, 2011 | 12:12 PM
YEW FAIL's Avatar
does a regular scanner pick this up or does it have to be a special one?
Old Jan 30, 2011 | 12:15 PM
insylem's Avatar
It MIGHT I dont know for shure, but I think the regular scanner only gets Powertrain codes.
Old Jan 30, 2011 | 05:32 PM
rnjmur's Avatar
Alot of times it depends on the problem. If it is a wheel sensor a normal scan should pick it up. I think you need a tech 2 to access the ABS module.
Old Jan 30, 2011 | 08:40 PM
mrbelvedere's Avatar
you can go to autoparts and get an abs scanner
Old Jan 30, 2011 | 08:55 PM
HyperMuffin's Avatar
You wouldn't be able to tell a difference in braking unless you were in snow or slammed on your brakes.
Old Jan 30, 2011 | 09:32 PM
G11's Avatar
G11
check your wires going to the wheel speed sensor...mine got corroded and broke just out of no where...had to get a new hub assembly to replace it
Old Jan 31, 2011 | 08:17 AM
JshLnsctt's Avatar
Mine came on yesterday too, thinking its probably a wire, though I'm going to try to get to autozone or somewhere to have them read the code for me.
Old Jan 31, 2011 | 08:36 AM
carstedt's Avatar
its your speed sensor in your wheel..mine did the same thing and i took it in and had to have the "speed sensor" in the back replaced and it never came back
Old Jan 31, 2011 | 01:26 PM
JshLnsctt's Avatar
When I changed my tires I noted on my car that one of the lines had a few slices in it from the mounting clip, I'm assuming that's where my problem lies.
Old Jan 31, 2011 | 08:03 PM
ThiZo_19's Avatar
LMAO.....GET IT SCANNED thats the first step to a proper diagnostic!
if u start swapping parts without even knowing the problem....u better have deep pockets.
if u dont have a scanner handy, at least visually inspect the system.
Old Jan 31, 2011 | 10:02 PM
carstedt's Avatar
car was under warranty and i also scanned it and inspected it...good try tho
Old Jan 31, 2011 | 10:34 PM
Davy_Baby9's Avatar
My ABS light has been coming on every time the road gets wet. I figure it's a sensor and the dealer wants $90 to scan it and if it's under the drivetrain warranty it's all covered, if it isn't then I have to pay.
Guy at Autozone said he couldn't scan chassis codes, if that helps.
Old Jan 31, 2011 | 10:41 PM
BLue NoTe's Avatar
Common problem I guess, mine comes on and off routinely. Im gonna thoroughly check it out when I swap my springs
Old Jan 31, 2011 | 10:45 PM
Phyrric's Avatar
My popped on after racing from a dig with bald tires and spinning till 50, I drove home and turned the car off and on again and it was gone, But I assume you've already done that haha
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
