adjustment for bypass valve actuator?
Old Aug 3, 2010 | 01:03 PM
kyle1853's Avatar
i notice out the bolt hole are ovular. is this an adjust ment for how much boost it allows or does it not matter how you put in in?
Old Aug 4, 2010 | 12:17 AM
NOLAGSS's Avatar
from what iv been told the actuator rod should be contacting the screw if you look you will see what i mean. and mine wasnt at one point and once adjusted i went back to full boost..
Old Aug 4, 2010 | 04:10 AM
rukkee's Avatar
What i used to do is back the adjustment screw out until you can feel the bypass valve bind a little in the port .... then screw it back in till there isn't any bind at all.....then test it . I marked the screw so i knew exactly where it was before i moved it ....just incase .
Old Aug 4, 2010 | 11:42 AM
kyle1853's Avatar
Contacting the screw while car is or when reving?
turbochargedss2012
Sep 20, 2023 12:17 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
Sep 27, 2015 08:53 PM
