Advantages/Disadvantages over 2.6???
Old Jan 4, 2009 | 03:08 PM
HOT CARLS SS's Avatar
Guys,
Seeing what the advantages/disadvantages over the ZZP 2.6 pulley too the ZZP 2.7 pulley....???? Hp/tq differences etc...heat???
Old Jan 4, 2009 | 03:10 PM
Dayta's Avatar
your overspinning your supercharger, HEAT SOKE x100000000, need all the cooling mods you can possibly get and you prob would get better hp numbers with a 2.8 or 2.7
Old Jan 4, 2009 | 03:11 PM
M88ArRamadi's Avatar
tons of heat!!!!
go with 2.8 with tune and cooling mods to keep it safe
Last edited by M88ArRamadi; Jan 4, 2009 at 03:11 PM. Reason: Automerged Doublepost
Old Jan 4, 2009 | 04:24 PM
ralliartist's Avatar
2.7 pulley will put you at the m62's max 16000 rpms at roughly 6875 engine rpms. after that, you are overspinning the blower and making tons and tons of heat.
2.6 pulley will put you at the m62's max 16000 rpms at roughly 6600 engine rpms. after that, same scenario, overspinning and tons of heat.
So the downfalls, is that you have to shift sooner because of the heat and power loss at high rpms, but you don't want to shift sooner because of the rediculously long gearing in our cars. You'd much rather shift higher and use your gearing better, if you shift sooner, you will fall out of the power band when you hit the next gear.
Old Jan 4, 2009 | 07:59 PM
blacksssc06's Avatar
All worng m62 is max mean overspin is @27psi at 16,000rpms. Ask eaton that's the max not a2.6pully that 20psi and yes u still make a lot of heat but not overspining I'm running a 2.6 with 32 of timmong with meth and my iat2 say at 82 and I don't have a dual bybass plate just meth
Old Jan 4, 2009 | 08:07 PM
So ralli...what rpms do you shift at and what pulley are you running?? Blacksssc06 what gains did you get from the 2.6 pulley in hp/tq? What meth mix are you running???
Old Jan 4, 2009 | 08:13 PM
Meth 40/60 mix and not sure yet getting it dynoed soon but I raced a bmw m3 the one with 330hp and he had a intake and catback and we raced he beat me but I was at his door the whole time so I got to be dam close to 300 or at or over
Old Jan 5, 2009 | 11:36 AM
ShortStack's Avatar
Dude. Stop talking.
Id stay with the 2.7
Old Jan 5, 2009 | 12:25 PM
I shift at 7500rpms and I'm running a 2.9" pulley. blacksssc06, you are wrong. lol. You shouldn't be making 27psi and eaton doesn't rate this supercharger at a max of 27psi. They rate it at a max continuous rpm of 14,000rpms and a max instant rpm of 16,000rpms. I just know the formula for figuring out what each pulley will "roughly" put the supercharger at per the engines rpm speed.
blacksssc06, what are your track times on your setup?
Last edited by ralliartist; Jan 5, 2009 at 12:25 PM. Reason: Automerged Doublepost
06SS ALL DAY's Avatar
wow i feel like a bitch with a 3.1 lol right now i'm trying to get a 2.9 or 3.0 but nobody is willing to trade arggg. i'd stay witha 2.7 or 2.8. is this car Track Only? if so, go get the 2.6 and have at it
Old Jan 5, 2009 | 01:07 PM
13.1 to 12.8 in 1/4 if I spray I could hit low 12s. And the point I'm trying to make is that a 2.6 is fine with meth and a good tune I don't have the heat soak issue that poeple seem to have and saying you need mad cooling mods u just need one or the other and that I can make some power with a 2.6 I mean if u want safe yea go with a 2.8 u want hp numbers go with a 2.6
Ok than why would JBP make pullys all the way down to like 2.4 and I think they got a 2.3 too that 23psi why would they make them if the superchager can't handle it
Last edited by blacksssc06; Jan 5, 2009 at 01:07 PM. Reason: Automerged Doublepost
Old Jan 5, 2009 | 01:37 PM
ShortStack's Avatar
For people who either dont care, or people who are unaware of actual mathematical facts that prove danger.
And were not saying it wouldnt work, but it WIL cause problems in the future.
Old Jan 5, 2009 | 01:52 PM
I agree it well kill the m62 faster with a 2.6 or smaller
Old Jan 5, 2009 | 02:40 PM
Zooomer's Avatar
Supporting Vendor
The M62 cannot be destroyed or damaged by over spinning it. That part of the debate can end because it's not an issue.
The real issue is in the application of this blower on this car. Pulleys smaller than a 3.0 are not going to produce additional gains on the 2.0 unless you have more displacement, cams, or a ported head. The boost levels just get too high to benefit. As boost levels climb the power required to spin the blower rises and therefore gains diminish.
As boost levels climb, so does heat and cylinder pressure from additional air. This reduces the timing you can run which lowers HP. This is why you can hit 260WHP with a 3.1" pulley. If you look at any hpt file, you'll notice timing drops as airflow increases. This is true for a stock file, stage 2 file, etc. As timing drops from KR or from the table, HP will as well. Running a 2.8" over a 3.0 pulley can change the timing table by 2 deg (and more if you have KR). This will drop you approx 10HP by 7k rpm.
Additionally, a larger pulley allows you to run leaner which makes power on these engines. Larger pulleys are safer.
Nearly this entire community has a great misconception on small pulleys making more HP and I'm not sure why people aren't looking at the data. Add race gas or pure alcohol and the optimum pulley size may be smaller but for now forget about the 2.x pulleys and enjoy the 250+ WHP that's so easy to be had safely with 3.x" pulleys.
Old Jan 5, 2009 | 02:48 PM
ViLerocker's Avatar
I'm just here to listen in...continue...
Old Jan 5, 2009 | 03:22 PM
ShortStack's Avatar
Although it is very unlikely, im pretty sure it is possible to destroy anything ... but at a certain point, over spinning could cause seizure by over heating its internals.
How is your tuning going to be done? Either way, zoomer is right about making safer power on the 2.7 than the 2.6. Although if you were hardcore tuning and didnt care, the 2.6 would yield more power, but i dont think your going that route.
Old Jan 5, 2009 | 03:39 PM
WSFrazier's Avatar
To think, I ran 10:1 pistons, 2.5" ring on the blower w/ meth. Stock everything else. Car ran like a raped ape.
Why is it that the only people to crack 300whp without another power adder, are the ones with 2.5/2.6 rings... and no one else has done it yet?
If I got another one of these cars, I would put a 2.5" ring on it again without a second thought. It dropped the TQ curve so low, car was a blast to drive.
Old Jan 5, 2009 | 03:59 PM
Area47's Avatar
Rent me! per hour
because people are brainwashed. see above.
Old Jan 5, 2009 | 04:20 PM
OMG thank you
Old Jan 5, 2009 | 05:23 PM
Zooomer's Avatar
Supporting Vendor
We've run the older Eatons to 20k rpm without issue, this M62 could go farther w/o breaking although it wouldn't make much sense.
and no, he won't make more power with the 2.6. He'll make less. If he wants to go faster he should run a LARGER pulley than the current 2.7
We've shown people this many times on our dyno when they came in for tuning. Always the same thing..."how small of a pulley can I run" and then we show them on the dyno and they leave with a 3.0 or 3.1
Old Jan 5, 2009 | 05:47 PM
Area47's Avatar
Rent me! per hour
does torque not matter to anyone?!??!
seriously?!?!?
Old Jan 5, 2009 | 05:50 PM
WSFrazier's Avatar
seriously?!?!?
Exactly why I kept my 2.5" on. I tried using a 2.7", didn't last 3 hours.
I will admit, the HP increase might not be huge, but the movement of the TQ is very nice.
Old Jan 5, 2009 | 05:53 PM
1badBlueberrySC's Avatar
I have deff. noticed a nice kick in the pants increase from my 2.8 to the 2.7 now!
Old Jan 5, 2009 | 06:15 PM
fzn14's Avatar
Ya i plan on droppin to a 2.7 and increasing the timin in the tune shortly....
Old Jan 5, 2009 | 06:54 PM
I can clearly make higher up numbers with a 2.6 than a 3.1 with cooling mods so how can u say a 3.1 well make more hp??????
