Advantages/Disadvantages over 2.6???
one with a 2.6 and a intake and one with a 3.0 and a intake both cars have 60 injectors..one run on a dyno i bet you see better numbers with the 2.6 im not saying yeah go out and put a 2.6 on a stock bolt. no hell no you need the cooling mod but to say what these people are saying that with cooling mods a 3X whatever well make more than a 2.x no not happen like i said if you got the cooling mods more boost more power
where talking almost stock with cooling mods so yeah than i can see that but put now take to stock ss
one with a 2.6 and a intake and one with a 3.0 and a intake both cars have 60 injectors one run on a dyno i bet yuou see better numbers with the 2.6 im not say yeah go out and put a 2.6 on a stock bolt no hell no you need the cooling mod but to say what these people are saying that with cooling mods a 3X whatever well make more than a 2.x no not happen like i said if you got the cooling mods more boost more power
Please... use punctuation.
sorry but i had to chime in.. you didnt beat that M3 cause of heat soak. what happened to the vid/thread of the stage 2 balt beating an E46 M3? IT WAS BS.. you SHOULD be able to pull an M3 with that low of a pulley.. cause that 333HP that it has is BHP NOT WHP.. but you didnt.. you were right at his door cause of heat soak. and how the HELL does PSI have anything to do with MAX INSTANT RPM'S of the eaton? ive stayed door to door with an E46 M3 in a staged IRL with solid mount's cause of the mount's putting the power to the ground and making fast shifting EASY. still got beat but i was RIGHT with him. got my ASS handed to me by an M3 with the SMG transmission. dunno the mod's tho.. and IIRC the M3 does weigh jus alittle more than a balt...but has WAY better aerodynamics.
Wow there are some ignorant posts in this thread, people that dont understand how to make power with a car shouldnt post like they know everything, it just makes it hard for the newbs to learn anything about these cars when these dumb@sses post INCORRECT facts.
Of course a 2.5" pulley will make your car feel fast as hell, but you better shift it at 5k rpms so it doesnt blow up due to blower outlet temps being way to high. You will always feel gains with smaller pulleys in the LOWER RPMS!
I wouldnt rely on the boost being at unsafe/unefficient boost levels to "flatten" the powerband and gain torque.
Note to all: smaller rings aren't for everyone
Is that why one of your own employees runs a 2.55" on his GTP (Well, actually its a GT with some "bolt-ons")?
So, if the 2.5" & 2.6" rings are as useless as you guys (ZZP) make them out to be... then why do you sell them?
So why are you posting again?
See what i did there...
Its funny what's going on here...
ZZP is basically challenging all the people of this site that have made the highest numbers with the M62, the people who have made the quickest cars... and basically telling them that their cars might have felt fast, but they weren't; and that their 2.5 & 2.6 Pulley dyno sheets are garbage.
Reminds me of that time this one company tried to tell us that they made 440whp with a Twincharge Kit... but the only proof they had was a sketchy dyno sheet and a video of the rear end of the car on a dyno... i just can't seem to remember who that was though...
Guys I'm still trying to find out how I would make more power with a bigger ring I mean I got all cooling mods and a built motor so if someone can explain to me how???????
O and real quick I don't mean to side track, but I just put a zzp TB spacer on.I noticed that my rpm not in gear is at 900 it used to be at 800 rpm I also noticed that my clutch and brake pedel are stiffer and my A/F stay steader than when it used to jump around. There are no leaks I checked as anyone noticed this?
Last edited by blacksssc06; Jan 8, 2009 at 08:33 AM. Reason: Automerged Doublepost
Under the presumption that you work for ZZP, I make this statement:
Consistency in your story is the problem here.
Wow, some of you guys are really getting brave with your innuendos.
I understand that, but throughout this thread, it just seems like you guys are flip-flopping. There are many times that some of you guys make it sound as if there is no use in running a 2.5" or 2.6" because you'll make more power with a larger ring.
The intention of the post is to keep people from blowing up their cars and dispell the myth that smaller pulleys always make more power. And to correct the assertion that the blower RPM itself is a problem due to supposed bearing failure.
Point is that for nearly all people on this forum, a 3.1 or 3.0 pulley is ideal. There are some people, although few where a 2.x pulley would be a better choice but it's always better to err on the side of caution.
The 2.0 likes RPM so in a situation where you short shift the car, you never get to peak HP. In that case, the car is going to feel faster with a small pulley and even give better times at the track because the average HP will be higher due to lower engine rpms through the pass. However to say that this means smaller pulleys are better is a misconception. The engine should be spinning to a higher rpm with a larger pulley (possibly) which would increase the average HP of the pass due to a better powerband.
But back on recommended pulley size. If you run higher octane, the ideal pulley size drops. If you ran alcohol injection it would as well. However I hesitate to even say that because on this forum people think that alcohol and water are the same thing when in fact they are near opposites for purposes of induction. So the last thing I want to do is give the perception that you can spray blue washer fluid in your engine with a smaller pulley and make more power.
Back on ideal pulley size. It is depending on boost level of the blower. This is dependent on the car's exhaust, whether you run a cat, the barometer, engine displacement, intercooler efficiency, cams, head, etc. If you can get the boost level down, then ideal pulley size will drop. If you can't, then a larger pulley size will make better power. But no matter what the situation, a larger pulley is always safer and if you can make power with a larger pulley size, then that is the best route to go. I'm guessing that when we're running 11's with a stock M62 it won't be with a 3" pulley. It will be something small but the car will be setup so that boost levels are no higher than 16psi. Some of this is speculation of course since this type of build doesn't exist at the time of this post but hopefully it conveys the idea.
