Advantages/Disadvantages over 2.6???
Old Jan 24, 2009 | 10:54 PM
  #376
TRANSAM197781's Avatar
ok so after 21 pages i would like to know is the 2.6 worth it
Old Jan 24, 2009 | 11:05 PM
  #377
car_guy_09's Avatar
a 2.6 will make slightly more tq but more heat with it, My IMO is this, If you want every last once of power you can get, then yes.
If you want a little safer set up then do a 2.8 or 2.7
Old Jan 24, 2009 | 11:12 PM
  #378
djt81185's Avatar
Originally Posted by Zooomer
DJT, I don't have time currently to explain the entire paper but let me make a few points to show the flaws of your logic. BTW, excellent paper. The problem is that it doesn't apply to our situation and it proves my point in the respects that it does apply.
Here's why it's not directly applicable to the ecotec.
1. They are running a motor on 100% alcohol. We are running gasoline engines.
2. The tests are not at the same RPMs we're concerned with (although I'm editing because some are)
3. They are not increasing boost as people are doing here. This entire discussion is about increasing boost by using water injection with some alcohol. The paper has a fixed rpm and boost.
Here's where it does apply and proves the people mocking me 100% wrong. Allow me to quote your paper:
"At fixed ignition timing, the increasing addition of water reduces engine output,"
"The reduction in efficiency at fixed ignition timing
may be attributed to a reduction in burn rate and also
combustion stability, as would be anticipated with the
addition of a diluent"
"a reduction of output
in the order of 2% is observed from E100 to E93h, and a
further reduction of 2% from E93h to E87h."
I hope that most of you can easily understand what the tech article my opposition posted is saying. With no other changes, water reduced engine power
Now, I know what comes next. Claim of increasing timing, boost, etc. the article has more which I can break down as it relates to the combustion process at 2k rpm vs what we're doing, varying boost pressures, running on all alcohol, etc. I'll get to it. for Now I hope that people will read that article before posting and making any more claims about water not lowering engine output.
-Good stuff-
How about another quote "The exhaust temperatures follow
trends observed previously up to 4000 rpm, whilst at 5000
rpm the temperature of E93h exceeds that of E100,
indicating the relative loss in efficiency."
When you take stuff out of context to fit your argument it appears right. The key there is fixed ignition timing.
"The
key differences arising from fuel water content are reduced
burn rate requiring advance in ignition timing, increased
fuel mass flow rate, a decrease in engine emissions of NOx
and increase of HC, and higher potential for increase of
compression ratio and output."
When ignition timing, if fixed, power output stays the same or drops a hair. When tuning or adding boost or compression is done there are gains seen. You were originally claiming that adding meth and retuning thru compression, boost, or timing provided no gains or a loss. That is what this was posted in response too. I do not recall disputing the claim that water alone with no change in tuning,compression, or boost will cause a loss. If it was taken that way it was a misunderstanding.
Also none of these are running pure alcohol. One is different version of ethanol, one is 87 with water in it and the other is 95 octane iirc.
Originally Posted by Matt M
Zoom posted pages of technical information. The fact that you choose not to believe anything he posts does not mean that it doesn't exist.
I'd like some links please.
Old Jan 24, 2009 | 11:15 PM
  #379
i have a 2.8 just wondering if it would be worth the 2.6
Old Jan 24, 2009 | 11:17 PM
  #380
USMCFieldMP's Avatar
Rattlesnake Race Shop
It makes quite a bit more torque and just a little bit more hp.
Old Jan 24, 2009 | 11:20 PM
  #381
usmcfieldmp did you swap to a 2.6 and if so how do you like it is it worth the effort thanks
Old Jan 24, 2009 | 11:24 PM
  #382
car_guy_09's Avatar
ignore the newb that runs a 2.8 on 42's
Im kidding, He probably knows more than i do, so listen to what he has to say
Old Jan 24, 2009 | 11:35 PM
  #383
Matt M's Avatar
Originally Posted by djt81185
You were originally claiming that adding meth and retuning thru compression, boost, or timing provided no gains. That is what this was posted in response too. I do not recall disputing the claim that water alone with no change in tuning,compression, or boost will cause a loss.
a. Zoom has never claimed that meth can not increase power. He has stated time and time again that water or readily available washer fluid will not increase power. I can't understand how people interchange the three carelessly.
b. You may not have, but others have posted in this thread that simply spraying water with no other changes will not decrease HP. There's a lot of people arguing, so sometimes separate arguments get crossed.
As far as links- scroll back through this thread.
Old Jan 24, 2009 | 11:44 PM
  #384
djt81185's Avatar
When I use meth i mean meth and water mix. I know what meth alone can do.
But water/meth will make power when tuned for. Just as meth alone or water alone can when tuned for. As the documents show. When not tuned for its useless/can hurt performance and output.
In the last post of Mine i meant meth plus water.
I don't recall anything substantial being posted. Seemed like a lot of talk without a whole lot of proof.
Old Jan 24, 2009 | 11:52 PM
  #385
car_guy_09's Avatar
Im pretty sure nobody meant that, Your just nit picking again, Im sure what happend was you guys called it water injection, So somebody posted water injection meaning water meth mix but instead you guys took it as water to make you look like you know what your talking about.
I have yet to see somebody spraying straight water
Old Jan 25, 2009 | 12:16 AM
  #386
HOT CARLS SS's Avatar
Well boys and girls I think I am going too try the 2.6 and see how it goes...I am running meth and a large HE + Redline waterweter so I should be ok.... +_ I don't race it much just a little here and there....The torque should help alot on the street...
Old Jan 25, 2009 | 12:29 AM
  #387
sput's Avatar
Good Luck!
Old Jan 25, 2009 | 01:26 AM
  #388
Omega_5's Avatar
While methanol has lower energy content per unit, the stoich air/fuel ratio is far less than gasoline, meaning that you can effectively burn a lot more methanol with the same amount of oxygen.
Hence the reason for my clarification. Obviously these cars don't have the stoich value set at 6.4:1.
Either way, I think I understand what Zooomer was getting at.
Old Jan 25, 2009 | 05:58 AM
  #389
qwikredline's Avatar
I love my OTTP meth kit....works great...hp is there..
Old Jan 25, 2009 | 11:09 AM
  #390
Did you also notice all the top cars in the modded class are running 2.5,2.6" pulleys???? except Hatrickstu.....
Old Jan 25, 2009 | 11:29 AM
  #391
i did. but hatrick is smart .....and uses meth recreationally.....jk
Builttss
Oct 4, 2015 10:21 AM
n20saturn
Sep 17, 2015 01:55 AM
Bluelightning
Sep 8, 2015 05:18 PM
Modernceo
Modern Performance
Oct 11, 2006 01:06 PM
