Advice on what to do. Please help.
Old Feb 4, 2012 | 12:49 PM
Ryan07SS's Avatar
I have a 2007 Cobalt ss s/c with the stage 2 upgrade from gm with a 2.85 pulley. My car has not been running so great and got it scanned and its running lean. I dont want to change my 2.85 pulley so what do you all suggest? Im thinking about getting the zzp 60lb injectors but would I need to tune it after that or could I just run the 60's with the stage 2 tune? Im in a terrible bind and thanks for any advice you guys can give me. Btw I only have 500 dollars to spend. Much appreciated if you could lead a good guy in the right direction. Thanks .
Old Feb 4, 2012 | 12:51 PM
advise's Avatar
with 500 you could get a set of 60's and get off that shitty tune
a clean set of used 60 $150 and say $300 for a tune
best best and a decent power difference
Old Feb 4, 2012 | 12:52 PM
BPacak's Avatar
Vtec Rep
idk if you need a tune for a pulley but your gonna need one for injectors
Old Feb 4, 2012 | 12:55 PM
advise's Avatar
hes making the injectors go static with that pulley
Old Feb 4, 2012 | 12:57 PM
Silv3r's Avatar
2.9 is stretching it for the 42lb injectors... i wouldnt be running a 2.85 at all with that you have.
You have 2 options: buy a stock stage 2 size pulley, or get 60lb injectors and a tune.
Old Feb 4, 2012 | 12:59 PM
Ryan07SS's Avatar
Thanks for your reply man! The big question I need to ask you then is where can I get a tune? Do I just buy it off zzp or intense websight or do I need to go somewhere to have it done? Dont have any knowledge on tuning. If I have to go to a place to have it tuned then I wouldnt know where to begin because Im not even sure if there are any places around here that have any cobalt knowledge.
Old Feb 4, 2012 | 01:24 PM
Ryan07SS's Avatar
Ok I am on the zzp websight and Im gonna order the zzp 1.0 pcm . I added the product description that I have the 60lb Injectors and also put in the 50% boost reduction in 1st gear. I will have a shop install the injectors and the 1.0 pcm all at the same time. Shouldnt take too long for labor to have this done am I correct? Thanks
Old Feb 4, 2012 | 01:38 PM
05Slowline's Avatar
Should be a half hour
Old Feb 4, 2012 | 01:44 PM
brideout_8's Avatar
If you have any mechanical skill just do it yourself. The pcm just plugs in. Here is the how-to for the injectors https://www.cobaltss.net/forums/how-...jectors-22907/
Old Feb 4, 2012 | 01:47 PM
Ryan07SS's Avatar
Ok cool cool thanks guys !! With the 60lb injectors and the 1.0 pcm how much of a difference will I feel from now? Should I expect any power gains? I dynoed 247whp with the setup I have now thats 42lb injectors .
Old Feb 4, 2012 | 01:49 PM
metalmedic's Avatar
I'm sure u can find a local guy off the forms with hp tuners or a trifecta cable... would be a lot less of a hassle in the long run... pm james his user name is in my sig... he can prolly help u out...
Old Feb 4, 2012 | 07:09 PM
advise's Avatar
Post
Get a custom tune you will never idle right with 60s and a mail order tune
Old Feb 4, 2012 | 07:13 PM
advise's Avatar
Here's the tuning list its old so idk if these people still tune
https://www.cobaltss.net/forums/tuni...cations-86603/
Old Feb 4, 2012 | 07:18 PM
donkeyballs's Avatar
blazzin07? is from florida i think? He knows his **** so talk to him for a tune.
Old Feb 4, 2012 | 07:30 PM
Ryan07SS's Avatar
Ok so if its not gonna idle right then maybe I should change my order to the 50lb injectors that zzp recommends. I will have to call them on Monday and ask them . Let's say I do stick with the 60lb injectors, will it hurt anything?
Old Feb 4, 2012 | 09:45 PM
advise's Avatar
50lbs are going to limit yourself
60 are deff worth the money regardless off what their site say
50s will just probably just support your pulley
60s will give you room for future upgrades and make it so you wont have to buy new injectors later down the road
with a good custom tune you will make good power and idle just fine
idles rough with canned tunes but still do-able i talk from experience
pm me if you have any questions
Old Feb 5, 2012 | 03:16 PM
zfissette's Avatar
always step up the the largest you could ever want, the 80s can be tuned for a good idle and will support any future upgrades. skip the middle sizes and go right to the 80s.
Old Feb 6, 2012 | 08:36 PM
advise's Avatar
did you order your pcm and injectors
Old Feb 6, 2012 | 10:13 PM
wwalker85's Avatar
^^^ Would try that before I ordered a PCM.
Old Feb 6, 2012 | 11:03 PM
Ryan07SS's Avatar
Yeah they are shipped and on the way. Not too worried about the idle issue with the 60lb injectors, just need to fix the problem quickly before it gets any worse. I've been looking for tuners around central Florida so I will take that step alittle later down the road. Just wanna fix this problem quickly
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
DocSvensk
Sep 27, 2015 02:24 PM
NoBalt123
Sep 4, 2015 07:10 AM
