Aeroforce gague question
ok does anyone here have the new frameware for the aeroforce gagues its the 2.4 frameware? if so when you turn off your car does yours come with a set 'turbo timer' or 'cooldown time' w.e u wanna call it?
i had a few ppl on here that i know look at my car an they were in shock that the gagues have a bulit in turbo timer but theres no way to set it or turn it off
anyone on here has this same issue? an can help?
also setting the shift light i know how to set it but do i put the (.) infront or behide
example .6900 or 6900. an thats 2 program the shift light an it doesnt say set shift light on the menu it just says shift time for those without the new aeroforce that might be trying to help me
thanks in advance
thanks in advance
hey man i dont know too much about these but i was definatly thinking about buying one and wanted to know a little bit about it. Where does it plug in and what exactly does it read??? thanks PM if you instead
it plugs into the ODBII port, and it reads damn near every perametor your ECU has a sensor for...its a wonderful wonderful wonderful thing!!! checks trouble codes, does 0-60 and 1/4 times, shows real time HP numbers...everything!
thanks in advance
thanks in advance
For my version (older than yours):
The shift light setting should be 06500 or whatever you want it set at (there is no way to enter a . in any parameters in my version).
You turn it on by using the Annunciator function and then selecting RPM, and then your number and then selecting for it to turn on Above or Below the number you set.
For your reference:
Here's the version 2.4 User Manual:
http://www.aeroforcetech.com/files/I...AL_rev_2_4.pdf
Effective for all Standard GM and select Ford vehicles as of 2/10/08
Here's a link to their manuals page for others that might need different versions:
http://www.aeroforcetech.com/Usermanual.html
For your reference:
For your reference:
yah i did all that when i put in the zero it turns into a . infront idk why n i read that manual today to try an see why it wasnt going on..
shhh lol go back to work ur to busy 2 b online fcker lmao im waiting for sum1 2 reply 2 my post about my drilled n slotted cz im also doing my brakes as well n also we needa drill cuz the"father" hid his lmao
interceptor read everything going on with your car for when you change the pulley to make sure ur running safe as for the wideband that which i need also when changeing the pulley an tuned that your not running to rich to blow threw tanks of gas like water also another safety thing
interceptor says...."hey, you gots some knock, do something about it!" ...and wideband says "hey, you is gonna blow your car up, fix your fuel ratios"
wow this forum is way way wayyyyy off topic it became a chat room lmao
you still got your hids for sale lol
naw i sold those awhile ago but im kinda thinking about getting halos so now i might ..MIGHT lol keyword be putting the hi low beam kit up 4 sale not sure yet tho
haha do my sc also lmao
ok im leaving work like now lol
Sl0wbaltSS
Nov 21, 2018 11:11 PM
