Aeroforce Interceptor Intake pressure before supercharger ?
Anyone have done some datalogging (at Wide Open throttle) to see what is the pressure (vacuum) before the supercharger ?
Originally Posted by CleanNFun
wouldnt it just be atmospheric pressure...which is why the supercharger produces boost...its above atmospheric...I dont think there is any vacuum in there.
Edit: I just have a K&N drop-in in the stock airbox. I've never actually logged the data, but just watching it, I've never seen over about 0.3-0.4psi.
Originally Posted by Jmc007
Plus or minus 9 ?
Originally Posted by Drewfu$
That sounds like MAP sensor readings.
About the pressure at WOT before the supercharger (MAP sensor 1) :
Someone with the airbox mod get 0 PSI (at WOT) and another one with a CAI got the same result, we see that the 3" stock airbox intake isn't causing any restriction at all (with a high-flow filter).
The stock airbox have been designed by Donaldson, and only the stock air filter is restrictive. So replacing only the filter is a good idea.
Nonetheless, a CAI will give more look and probably a better whiiiiiiiiine too !
Originally Posted by DanM
That PID is SC Inlet VACUUM. It's physically impossible to have anything higher than atmosphere there, so the number MUST be zero or positive (positive vacuum). If anyone's gauge is sending a negative number, than you probably have an early version when AFTech was still getting the conversion right. Email them, and I'm sure they'd be happy to reprogram it for you!
Not if you are trying to twin charge your cobalt. I bet thats the single reason that little sensor is there, to keep people from boosting before the blower on the stock ECU.
Reviving an old thread ...
SC Inlet Pressure was reading today 0.2 PSI (vaccuum) at WOT with airbox mod (lower lid removed and K&N filter).
What are your reading guys with which intake ?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
z28addiction
Sep 28, 2015 12:03 AM
