Afermarket Pistons
Afermarket Pistons
Anyone change pistons on their 2.0s yet? More specifically, change comp. ratio? I'm kinda up in the air which way to go with this. I'm not sure if I want to dual charge and drop comp. ratio with the Mahle pistons or go with the Intense/Diamond set up with the 10:1. If anyone increased theirs, did you experience any increase in knock? Doesn't anyone offer 9.5:1 stock ratio but in a forged build? Thanks in advance.
I'm old school
Victory Red SS is the guy I know that has taken apart his LSJ. Drop him a PM.
Yeah, I guess my question is really, "Do I wanna dual charge or run high compression and a bottle." Its just clutch and pistons are my next upgrades and haven't decided which way to go yet.
LSX RWD S/C conversion
The stock pistons are actually a Mahle piston. As for the compression change I still can't tell you because the last piece we are waiting on are some custom cylinder sleeves from Bates. These should be in soon but everything is put on hold as Mev from JBP gets married this coming Saturday and then heads on a 2 week honeymoon. Then who knows how long it will take Mev to recoup from all the honeymoon sex his new wife will be getting.
Looks like the end of September before I can give you a different answer but I still may not be able to help you Witt, because of everything else we are doing to the engine. I would say just do it all and and be prepared for anything.
Cool, thanks for the reply. Right now I guess I'm looking at the Mahle forged pistons in anticipation of building a dual charged set up, which is kinda the way I'm leaning.
Originally Posted by 06blackg85ss
question for ya victory.... are the mahl ones that were posted up the other day stock equiv.. or better... I was interested in getting those.
Aaron from TTR can likely confirm this but my understanding is 8.5 is a lower than stock compression. Those pistons are definitely not the stock pistons but they are similar in design especially the piston head. Best of all these are forged. My understanding is these are for engines running higher boost without doing an extensive reworking of the engine.
