Aftermarket Shiftlight
Old Feb 13, 2006 | 01:15 PM
italstalnprd86's Avatar
Can anyone direct me to a reasonably priced aftermarket stand alone shift light unit? I want something nice, and that is not to expensive, and that you can integrate into the factory tach.... with the module things or whatever...... there are a ton on ebay, however i dont know what is good and what isnt....
Old Feb 13, 2006 | 01:17 PM
wikkymaster's Avatar
im also interested
Old Feb 13, 2006 | 01:42 PM
Hackas86's Avatar
Look on ebay i believe i saw one on there a couple days ago
Scott
Old Feb 13, 2006 | 03:29 PM
theBLUEone's Avatar
Scott
He said there are many on ebay, but he doesn't know which one is good...
I believe there is a Raptor shift light out there for us...
Old Feb 13, 2006 | 03:38 PM
croSSoverkid's Avatar
go to buttuglycustoms.com they are a dealer for the raptor performance shift light. its small, cool, and easy to install, there is also a how-to thread for it. i thinks its like $85.00 free shipping
Old Feb 13, 2006 | 06:41 PM
selfinfliction's Avatar
shift lights..... i would rather have a tachometer that showed the correct rpm's when accelerating fast lol
would a shiftlight even help? lol
Old Feb 13, 2006 | 06:59 PM
theBLUEone's Avatar
Well, yes. It uses a coil pack to determin the RPM's and you adjust it to where you want it to light up and tell you to shift so you do not have to keep an eye on the tachometer...
Old Feb 13, 2006 | 07:37 PM
03gobluecobra's Avatar
I have a raptor in the cobra and love it. My trap speed went up 1.5 mph from me hitting my shift points correctly, plus I don't have to watch my gauges so much. I've been thinking about getting one for the cobalt. Also, relatively easy to install.
www.raptorperformance.com
Old Feb 13, 2006 | 07:39 PM
Oh, and the stock tach is a little slow to respond, so a shift light will accurately tell you when to shift. I seem to hit the limiter in first in this car all the time, even before the tach hits redline. The tach just can't keep up with how quickly the RPMs climb.
Old Feb 13, 2006 | 08:08 PM
what i was insinuating is that the tach is so slow you usually hit the fuel shutoff before it hits the redline in first and second gear
Old Feb 13, 2006 | 08:44 PM
BlackSS05's Avatar
with the gauge installed it did help me miss the fuel cut off from 1st to 2nd. I also bought it from raptor. gauge is awesome mounted it on the steering column so its visible. light is bright enuf so that you pay attention. installation took about 3 minutes. i already had a whole drilled thru the firewall tho.
Old Feb 14, 2006 | 01:13 AM
well guys after looking, i would rather spend 75 on the autometer one then 85 on a raptor.... so im thinking of the autometer one that you get the little rpm things for..... plus it matches the boostgauge and autometer is good stuff
Old Feb 14, 2006 | 01:16 AM
Our tach does seem slow, however i think it is accurate... the same is the case with the speedo, me and my buddy had the same thought so we hooked up the obd2 to it and took it out on a little ride to see what it said, and sure enough the numbers matched... pays off to own a shop and be able to use that little thing, i also found out i have no knock, what my air to fuel ratio was, and some other **** too.... next time we hook it up, i am going to find out how much torque the crank is seeing, couldnt do it last time as we couldnt find the other part you need to plug in....
Old Feb 14, 2006 | 01:18 AM
hey man, where are you shifting at, and if you drag, where do you let out the clutch to avoid loss of traction, i am thinking of starting at around 2500, and shifting around 6000, do you think that sounds about right?
Old Feb 14, 2006 | 02:58 AM
Badmunky's Avatar
IM geting the Raptor shift light my self. Just need to get a few other things first.
later
Old Feb 14, 2006 | 10:38 PM
Knightrider22's Avatar
Raptor **** lights are the best
chefhhr
Oct 26, 2015 10:36 PM
metroplex
Sep 27, 2015 07:48 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
budah93
Sep 15, 2015 07:23 AM
