Intense Stg 3 installed!!!!!!!!!!
Old Feb 12, 2006 | 02:38 AM
Ljavy17's Avatar
after working at it for more than 8 hrs, yeah 8hrs it took to install the whole kit, i can say that every single minute of it was worth it. Its unexplainable how much stronger this car pulls. I mean literally you punch in second going from 40mph and it feels exactly how it used to feel when I used to punch it in 1st going 20. No lie guys. I mean i will need new tires very very soon. It frigging peels out in second man! at 2000k RPM i think i was boostin like 12 lbs and at 4000 i was already at 15 and redlines at like 17.
Go out and buy this kit! its well worth the money, and very clean install, make sure you have time on ur hands tho.
I will be dynoing asa I get some more money , Im broke right now.
Old Feb 12, 2006 | 02:40 AM
3fo893013L's Avatar
glad you like your results. post videos ASAP
Old Feb 12, 2006 | 11:33 AM
plyboy-illest's Avatar
sounds impressive cant wait too see the dyno #'s
Old Feb 12, 2006 | 11:40 AM
Chevypowered's Avatar
good to see that you got it all together. How did you end up getting the hub on?
Old Feb 12, 2006 | 11:55 AM
shcwv's Avatar
why did it take 8 hours?
Old Feb 12, 2006 | 12:06 PM
Waylin22's Avatar
congrats on the install dude...post vids asap
Old Feb 12, 2006 | 12:16 PM
Dman's Avatar
yeah, did you not get the plug and play version? explain the 8 hrs...lol
Old Feb 12, 2006 | 12:29 PM
jmartinez's Avatar
got 1 question did you have to buy a belt adustable tensior? im want to buy the kit just want to know what else i need.
Old Feb 12, 2006 | 12:35 PM
Ljavy17's Avatar
for example, first we coulnt find the bolt for the tensionerto slacken it, But then I actually did what Zinner did and just a screwdriver to push it down and slacken it while I took off the belt of the supercharger, It was a lot of little thigns that happen to beginners that got us stock, from not being able to put on the pulley back on the supercharger because when we were taking it off we destroyed a plastic piece that goes on the tip of the hub so we couldnt figure out how the pulley would get pressed in until we realized that it was a piece of plastic that was still stock in the whole werhe we were soppuse to screw the pulley puller to the shaft on the supercharger to be able to put the pulley back , I mean its very hard to explain in person, also when were trying to take off the fuel rail we dropped on of the bolts from it and we thought it had gone in one of the holes where the injectors go! Oh man was I scared then but I realised it was between the engine stuck all the way on the bottom which there was no way to get it from the botttom but from the top, Our luck was baaaad, we had to use out friend with the skinny long hands to be able to get it while I would push it up from the bottom, then another time consuming thing was when we were trying to put the belt bakc on, it took three of us to get this done,
And finally when we put id back togehter and it was ready to go that we crancked it, the car did a loud POP like something blew, after three tries we took all the AIR out of the injector rails and it turned on fine, I still have to get my AF gauge on and interceptor but the car seems to be runing soo hard, I cant wait to race some srts and EVoS,
I mean the car really seems pretty hard to beat now. Ima be running it hard now.
Old Feb 12, 2006 | 12:38 PM
victoryredss's Avatar
go to the track! I really wanna see some runs with this kit
Old Feb 12, 2006 | 12:47 PM
Ljavy17's Avatar
my next mods are gona be some lighter rims, sticky rubber, and a new clutch and flywheel. 12s!!!!!!lol
Old Feb 12, 2006 | 12:54 PM
SS4LIfe's Avatar
i raced someone with this kit and we were side by side up untill 115mph after a 2nd gear roll, so do you think there is something wrong with his kit or what.
Old Feb 12, 2006 | 12:56 PM
Ljavy17's Avatar
what r ur mods, what are his settings on the MAF T, did he Dyno tune it. I mean ill tell u this man, back then when I had exhaust and intake I felt very veyr little gain in power with this kit the car feels like a whole totally different car. so if your stock or got minor mods, I donnu man.
Old Feb 12, 2006 | 01:00 PM
i bet his clutch is slipping thats why he got you in the higher speeds! theres no way you should be able to hang with it!
Old Feb 12, 2006 | 01:09 PM
SS4LIfe's Avatar
that what i though but we were on the highway and everytime i switch gears he was switching at the same time. and my clucth isn't that great either.
Old Feb 12, 2006 | 01:30 PM
Dman's Avatar
you sure he wasnt just lying to you??
Ljavy17...did you have to do the boost bypass mod?
Old Feb 12, 2006 | 01:36 PM
memphisr24's Avatar
Yeah did you have the boost bypass mod done??? Shouldn't you be boosting around 18-19 with a 2.8 pulley or is that with the 2.7?
Old Feb 12, 2006 | 02:05 PM
SS4LIfe's Avatar
he popped the hood and saw the pulley and he has a GMPP exhaust, i didn't see the injectors and translator but i know the guy i don't think he would lie about it.
Old Feb 12, 2006 | 02:10 PM
Alex47's Avatar
Sweet dude. Post up some pics of the engine bay
Ljavy17's Avatar
Oh yeah man, I already had the bypass mod from before, so its boostin nice. And yeah that guy just had a pulley man, No stg 3 intense kit. The maf translator goes right on top of the battery cover, one of the good thign about it is that you can have it in a reachable area so putting or hidding it would be pointless unless your going to ur dealership.
and I mean , it was last nite at frigging 2 in the morning when we finished man, Ill take a closer look today at much im really boosting and update you guys.
Old Feb 12, 2006 | 02:15 PM
Ljavy17's Avatar
im gona try to see if I can post some vids. and pics later.
Old Feb 12, 2006 | 02:21 PM
Badmunky's Avatar
Cool. Did you have to take the SC off to change the pully?
Later
Old Feb 12, 2006 | 02:22 PM
Alex47's Avatar
Cool
Old Feb 12, 2006 | 02:23 PM
memphisr24's Avatar
Im buying this kit as soon as I get my car back. I already have a 2.8 inch pulley so im just going to buy everything else.
Old Feb 12, 2006 | 02:35 PM
memphisr24's Avatar
Is there any slipping of the supercharger belt?? You are running the stock belt right? See I have the South Florida Pulley Headquaters 2.8 non slip pulley. I know the intense pulley hasn't really been slipping from what i've read. I wonder if the pulley i have will slip or not.
