Air con delete pulley & brk
Old Jun 10, 2008 | 01:17 PM
A11VXL's Avatar
Hi, In the past have seen somewhere an air-con compressor delete bracket and idler pulley. But as hard as I try I cannot find who makes these, can any one help? Thanks
Old Jun 10, 2008 | 01:18 PM
Eco-Mod's Avatar
I've been looking for one as well, the last time I tried getting one made the company I talked to stopped replying to my emails inquiring about them.
Someone able to shed any light on the matter?
Old Jun 10, 2008 | 03:33 PM
A11VXL's Avatar
Can you remember who was selling them in the past?
Old Jun 10, 2008 | 03:35 PM
BigTizzle903's Avatar
i was considering doing this myself, until this ridiculous heat wave, i think i like ac now lol
Old Jun 10, 2008 | 08:17 PM
Eco-Mod's Avatar
Mantapart was the company 'working on' a solution for me.
Old Jun 11, 2008 | 04:32 AM
A11VXL's Avatar
Thanks for that, doing a bit of a search last night and found that in the US the Aerial Atom is using/ used the LSJ (in the UK they only fit the Honda) does anyone know what they used,?
They also look to have a nice header too.
Old Jun 11, 2008 | 04:36 AM
REIGN SS's Avatar
Original Hayden Fanatic
you might try Nate at Smoothflow, he could possibly machine something for you
http://www.smoothflowpulleys.com/
Old Jun 11, 2008 | 06:01 AM
HunterKiller89's Avatar
whats the point though? the AC system cant weigh too much...
Old Jun 11, 2008 | 08:22 AM
A11VXL's Avatar
Hi I am using the engine in a VX220 here in the uk and the car does not have air-con also its only 870 kg so I really dont want to carry the compressor weight around
Old Jun 11, 2008 | 08:26 AM
Edubs's Avatar
Mantapart has a horrible reputation for screwing people over in the J-body world. I would stay as far away from them as possible.
On the flip side, Nate from Smoothflow has an excellent reputation here. I would contact him if I were any of you...
Old Jun 11, 2008 | 08:47 AM
A11VXL's Avatar
Thanks for the recomendation, I have looked at his web site and it looks good
Old Jun 11, 2008 | 07:45 PM
Eco-Mod's Avatar
Have you ever picked up an A/C compressor?
I don't have operational A/C as I have GM Stage 3, I don't use it often enough even if it did work, and losing weight off the front of these cars can do wonders!
Old Jun 12, 2008 | 06:40 AM
Speedytec's Avatar
Hi,
How far are you with the install?
My car is finally finished, so now I'm slowly working on my LSJ conversion. Just received a P12 LSJ ECU and I'm now working out the wiring. Want to make it as "plug & play possible" for my VX220/Speedster...
And an AC idler pulley would indeed be very usefull. Will ask the Atom Ecotec guys for this.
Old Jun 12, 2008 | 07:17 AM
06blackg85ss's Avatar
I have a non working A/C system myself... definitely looking into this so if anyone gets more info... post that **** up
Old Jun 12, 2008 | 09:14 AM
blacksssc06's Avatar
also with that said you get rid of the condensr than you got moe air flow to rad and h/e cooler temps
Old Jun 12, 2008 | 06:31 PM
Speedytec's Avatar
Asked around in the Atom forum and got some photo's from Bolus which helped me a lot.
The Brammo build Atom with Ecotec LSJ engine obviously has no AC, but also no idler pulley on that spot. The whole belt layout is different than the normal LSJ pulley system.
Off course the crank pulley and the SC pulley are in the same spot, but they have a 2,2 Ecotec belt tensioner and I think also the 2,2 alternator as it spins clockwise and the alt. pulley is different than the standard LSJ version.
There is a custom idler pulley mounted above the alternator and only a single-sided ribbed belt is used:
Hope it helps your build.
Old Jun 12, 2008 | 09:55 PM
qwikredline's Avatar
the Grand Am Cobalts use the stock Cobalt ac compressor gutted and dismantled, using the front pulley, bearing and pulley side ac comp housing for a simple reliable light weight idler that fits....
Old Jun 13, 2008 | 02:34 AM
nherbst454's Avatar
If anyone happens to be located in the twin cities and wants to swing by my shop we could try to come up with some sort of AC delete kit.
Feel free to PM me if you're interested.
Nate
Old Jun 13, 2008 | 06:59 AM
damnit if I lived close I'd be there in a second
Old Jun 13, 2008 | 01:25 PM
Eco-Mod's Avatar
PM Sent! (Close to the Cities)
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
