Air Fuel Ratio. Sensor Mounting Trouble.
Old Oct 19, 2009 | 04:34 PM
SloBaltS/C's Avatar
2007 Cobalt SC what location on Exaust should it be mounted i have heard too many things Such as certain distance from exaust tip. And so far down from the cat BLAH BLAH BLAH Please Help.
Old Oct 19, 2009 | 04:37 PM
ShortStack's Avatar
wideband or narrowband?
It needs to be before the cat. Thats really about it. 18" from the head is what most people say.
There is absolutely no reason to make 3 different threads.
Last edited by ShortStack; Oct 19, 2009 at 04:39 PM. Reason: Automerged Doublepost
Old Oct 19, 2009 | 04:41 PM
NOLAGSS's Avatar
if ur using a wideband the sensor needs to be in the downpipe before the catylatic converter. do not mount the sensor upside down either due to deposits from the engine will not burn off... before u drill the hole and weld it in MARK the spot with the down pipe ON the car.. iv found on my car and a frreinds lsj welding the bung on a angle facing the drivers side is the best fitment..
Old Oct 19, 2009 | 07:04 PM
SloBaltS/C's Avatar
wideband
Old Oct 20, 2009 | 12:45 AM
auggie_ss_phx's Avatar
this is were mine is at
Old Oct 20, 2009 | 07:41 AM
SloBaltS/C's Avatar
augge isnt that after the CAT? NOLAGSS Where Is Yours Im Thinkin Of Running CATLESS GOOD IDEA BAD IDEA?
Old Oct 21, 2009 | 12:25 AM
i had my cat taken out when i did the bung for the wideband
with cat
i have no cat
you could see were my cat use to be and the bung is before the cat
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Oct 1, 2015 10:00 PM
DocSvensk
Sep 27, 2015 02:24 PM
