airbox mod to the next level
Old May 12, 2006 | 09:11 PM
EthensCobalt's Avatar
ok so i wanted to know what would happen if you took you airbox out and just attached a filter i done this in an old car that i had and it worked like way better.................. what would be the problems of the sensors unconnected and so forth.
Old May 12, 2006 | 09:22 PM
cashstacker's Avatar
it's already been done just take off the bottom and drop in a K&N filter. you cant put the filter anywhere else do to the airflow sensor.
Old May 12, 2006 | 09:26 PM
TexasPhil's Avatar
what you are talkin about is pretty much THE airbox mod
Old May 12, 2006 | 09:37 PM
im talking about removing the airbox altogether......... thefore leaving the sensor connected to nothing
Old May 12, 2006 | 09:43 PM
Asphalt Assault's Avatar
hhmmmmm..... it would run with out the maf or at least not properly. computer needs that MAF to determine how much gas to be injecting by the input from it.
Old May 12, 2006 | 09:46 PM
............. i had it pulled off but before i posted this,so before i put it back together i thought i would ask.... give me like 5 mins
Old May 12, 2006 | 09:50 PM
done.......... way louder than with the airbox on
gettin cel tho
Old May 12, 2006 | 09:54 PM
how does reseting the pcm work ?
leave car running and disconnect the neg or turn off the car
and does it make a difference if i pull the positive one
Old May 12, 2006 | 10:10 PM
ggarcia86's Avatar
when i was dynoing my car at my school we unhooked the intake hose and put a cone filter right on the end so that i was not using the maf and i got less hp
Old May 12, 2006 | 10:31 PM
your lucky you didnt go to lean and burn a piston.
Old May 12, 2006 | 10:32 PM
depends you may have to go to the dealer.
bigdeertz
Nov 17, 2016 09:41 AM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
