Airbox mod problems ?
Old May 9, 2006 | 02:22 PM
EthensCobalt's Avatar
I done the airbox mod and man what a difference.
But I was wanting to know if there are any neggative effects to doing it.
Acidangel_5.0's Avatar
airbox no longer looks how it did?
Old May 9, 2006 | 02:25 PM
no removing the bottom and putting in k&N
Old May 9, 2006 | 02:26 PM
R33P3R007's Avatar
360 L337 User
Some people got a CEL
Old May 9, 2006 | 03:22 PM
silverSS's Avatar
hydrolock, but possible with any CAI
Old May 9, 2006 | 03:33 PM
Asstyme's Avatar
Did you leave the lid off or put it back on ? Which filter (part#) did you install ? What is the "difference" you notice ?
Old May 9, 2006 | 10:22 PM
i left the lid off... i forget the part number but it is the one that fits straight in their i think the e077. the car is way louder have no proof of gains tho
Old May 9, 2006 | 11:11 PM
Blown 4-banger's Avatar
What is the air box mod? I'v heard it around the forums for a long time, but never knew what it was. I ended up just getting a K&N cai, but I'm still curious as to what it is.
Old May 10, 2006 | 01:05 AM
knatsabooh's Avatar
The Airbox Mod is essentially making a cold air intake with the stock airbox. You Take the bottom of the plastic airbox cover off and place in a K&N air filter slightly adjusting your stock box for the new filter, make sure its secured with a clamp or some safe means. You then just don't pop the bottom of the airbox cover on and boom cheap col air intake. I did it to mine and it really made the supercharger whine through 2nd and 3rd gears. Feels a litttle stronger in the pulling department too. The only real difference is the steel piping you get in a cold air kit that i see.
Edit* doesn't have to be a k&N filter, i think others have used typhoon's, i grabbed mine at Canadian Tire until I get a K&N cause the place i ordered from keeps not ordering it? Plus this one works fine, Canadian Tire model, 3' diameter i beleive... works good tho.
Old May 10, 2006 | 01:22 AM
italstalnprd86's Avatar
not to hijack the thread, but i have a brand new fujita cone filter for sale with a stock airbox, well what is left of it, all plastic has been sawed off, and only the bolt holder things remain! $50 shipped if anyone is interested, all you have to do is swap the airbox, and screw the MAS in and your good to go... The filter alone goes for around $50 so this is a good deal for anyone not so sure about an intake yet, better yet, you still have your stock airbox intact....... PM me if interested
Old May 10, 2006 | 01:28 AM
Do you guys do the air box mod as a temporary solution or is that your permanent mod? It just seems like you can't get as much flow with that big... thing with a snorkel thing sticking out, as you can with a tube and a filter stuck on the end.
Old May 10, 2006 | 01:35 AM
like i said, man, no snorkal on mine....... i had it for about 4 months till i got my intake for xmas...... works great, cheap too, your getting basically a K&N cone, with the airbox... all cut down.... for $50 shipped... it is a fujita brand new in the box, and comes with a clamp... it is dry, so you have not to worry about getting any oil on the MAS
Old May 10, 2006 | 01:43 AM
knatsabooh's Avatar
Depends for me its temp, the only thing i worry about is the cold air intake voiding my warranty.
Old May 10, 2006 | 04:06 AM
Asstyme's Avatar
How did you get the filter to not drop out the bottom ?
Old May 10, 2006 | 09:20 AM
knatsabooh's Avatar
I crossed two pieces of wire through the screw holes that normally hold the bottom piece on. Works good and holds it nice and secure.
Was just a small flexible black wire, i've heard of others using zip ties in this crossed like pattern, others drill a hole up where their k&N clamp screw is in the airbox and tighten it that way to hold it secure, i didn't wanna mark up my airbox so this worked good for me in that sense ( wire crossed and holding it up. )
Old May 10, 2006 | 01:41 PM
Asstyme's Avatar
Does anyone know if the e077 comes with a clamp on the filter end so I could just drill a small hole in the airbox and tighten it down.
Old Dec 7, 2007 | 11:30 PM
real_s_player's Avatar
i just took off my lid off and my filter hasnt come out or falling out so i dont think u really need to hold it but if u want to be sure is not going to fall yea u can put something to hold it
Old Dec 8, 2007 | 01:22 AM
da_kage's Avatar
if you're going to do the air box mod don't hack apart your air box. here is how one member did it and this is how i'm going to do it as soon as the winter is over.
https://www.cobaltss.net/forums/pictures-videos-64/another-airbox-mod-option-76515/
Old Dec 8, 2007 | 05:17 AM
LopsidedJester's Avatar
nice resurrection, you can also drill a small inconspicuous hole for a screwdriver to fit on your clamped air filter like i did. Its a little tough to get it perfect, but it works.
Old Dec 8, 2007 | 05:57 AM
JERMzSS's Avatar
.............Dude you need to go put your lid back on ASAP!!! If your talking about your factory filter its open on both ends so your car is getting unfiltered air. The air box mod works with a cone type filter only.
Ive got close to 20,000 miles on mine since I did it and ive had no problems at all.
Old Dec 11, 2007 | 12:54 AM
hey finally put my oem exhaust back and u can hear da wine of da sc and da **** is lounder dat wat expected
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
