AIS Meth install help
Ok so I am having a problem with my ais meth system install. I have a new system that I got from ais and the boost switch is not connected to the pump and was wondering does it connect to the pump or what do I do with it just leave it hanging there here are some pictures. of the boost activate switch and the pump.
Should be a wire that comes from the pump, and connects to the prong on top
the middle prong is a (always on switch, to dbl check to if it's working)
the bottom prong is to give power to the entire unit.
Just one more question. I have a low level sensor in my meth tank. It has two wires and both of them are black I was wondering what one is the ground and what one is the positive. I need to know this so I can hook up the LED. thanks
