For all you with Cam Gears...
How did you install them? I have recently been reading some of the 153MB of ecotec documents and just realized that I might have aligned mine incorrectly. When I put mine in I went to the center line and called it good....I installed mine with NBS and a TVS w/2.75". I use my scan gauge to see tuning progression....before I would hit 310HP with 15psi. After the install I was at 449HP with 23+psi (gauge maxed out then zero'd). The car spins instantly in 2nd at 40mph and catches around 60mph. c/gl was IIRC 1.47 and I was at 17* timing. Other mods in my garage. I've blown 2 engines already and really don't want to blow another one!!
Please stay on topic...as I want to learn and fix this.
I got nothing, but I'll post up some more info to help you out.
Here is his mod list.
60 lb Injectors w/ harness
HARROP TVS w/2.75
Oversized Supercharger Tensioner Pulley
Stage 2 Drive Belt
Injen Cold Air Intake (non-fittin piece of $4!t!!!)
Vibrant Headers w/Down-Pipe - STAINLESS
Vibrant 3” Cat-Back - STAINLESS
SPEC Stage 3+ Clutch
Fidanza Aluminum Flywheel
Cometic MLS Head Gasket (0.040")
ARP Head Studs
Diamond Forged Pistons (10.5:1)
GM NBS
GM Cam Gears
Ferrea Valve Springs
Ferrea Valve Spring Retainers
Ferrea Seat Locators
Pauter Connecting Rods
Blow-By Oil Catch Can
Methanol Injection (375ml)
HP Tuners
NGK Iridium IX (BKR8EIX-2668)
Mobile 1 Fully Synthetic
2-Pass Intercooler Plate
180* Thermostat
LS4 TB
Valve Cover Cap Filter
JPB Control Arm Bushings
Polyurethane Engine Mounts
Polyurethane Transmission Mounts
GM Cam Gears
HARROP TVS w/2.75
Stage 2 Drive Belt
ARP Head Studs
GM NBS
GM Cam Gears
HP Tuners
180* Thermostat
LS4 TB
GM Cam Gears
I don't remember getting too much knock....I had some on my org. tune but that was at 20-22*. So that's why I lowered to 17*
Basically
Basically
If they are bolted onto the cam and not crooked, they are installed correctly. You can mistime the chain if you don't line up colored links correctly though. Sounds like yours is setup correctly, my car does exactly the same as you describe above.
All marks were lined up exactly....but when when I tightened the 3 13mm bolts down<<<what's the correct position?
I know the are "installed properly" I'm really unsure if they are "adjusted" properly.
how do I know if the cams to gears were properly "timed"
It would be so much easier if i could show you......typing sucks
If you want to preserve the ground LSA set both cam gear to the center position. Any adjustments made are in degrees that vary from the original ground LSA.
ground LSA?
Mine are directly in the center....so I guess They're done correctly. Now I just have to get a tune. I can't wait until I get to MD....seems like all the tuners are out that way
lobe slack adjuster ???
I'm old school
Are you talking about the GMPP adjustable cam gear set? Because if so, you really can't install them incorrectly. I supposed if you might be able to put them on backwards, but it would be obvious if you did that because you wouldn't be able to reach the adjustment bolts. I have that set on my engine.
Thanks for all the help guys
Sign_Something
13
09-26-2015 11:44 AM
