another exhaust cut-out question
Old Jun 2, 2009 | 11:07 PM
TxLonghorn#1's Avatar
Question another exhaust cut-out question
This is my current set-up:
Corsa Touring Exhaust
GM Stage 2 w/stage 3 pulley
Vibrant Long-Tube Headers w/dp
CAI
I want to install my exhaust cut-out that I have, but I'm not too sure if it will give me power; whether it's torque or hp or even both. My exhaust is 2.5 from header back. I'm not sure as to where to install the cut-out. I thought the best place to install it would be in the downpipe, before the cat. Is this ok? I just took my car to a shop and the guy said that it would be a tight fit and plus the wires for the 02 sensor isn't long enough. He also mentioned that he would have to remove the cat fron the downpipe, and install it closer to the resonator, in order to get enough room in the dp. Should I do this method? Or, he said to take out the resonator and weld a pipe there with the cut-out welded to the pipe. What should I do? Where would be the best place to install it power wise? I've seen some videos on youtube and I have also read postings here on the site, but nobody has a set-up like I do that has installed a cut-out. Please come foward if you do. If you don't have this set-up...please advise or just help me out! It would cost $65-1hr to $95-1.5hrs.
Old Jun 3, 2009 | 01:43 AM
silverbullet08's Avatar
I have the same exhaust set up with no cut out. The car is loud as F**K really too loud when im on it. I did hollow out my cat though. People are probably going to say that wont make it any louder but everyone i know and myself said there was a huge difference in sound. Plus you seem a little faster with the 6" flame you throw between 2nd and 3rd when your on it hard lol. Thats what you need to do if your looking the get more power or more sound. cut out always seem to leak and give that annoying lawnmower sound ptptptptptpt. At least all the ones i have seen.
Old Jun 3, 2009 | 12:52 PM
leviticus88's Avatar
for ease of install i'd say after the cat but I have no idea what your Longtube with dp looks like so maybe there isn't room.
Personally i'd say don't do the cut out unless you are planning on going with a turbo or tvs. the 2.5 inch exhaust is plenty for any m62 lsj. (a little back pressure is a good thing on an SC 4cyl)
Old Jun 3, 2009 | 06:24 PM
bump...for more input
Old Jun 3, 2009 | 08:47 PM
coopn8r's Avatar
My cutout is located at the downpipe right before it gets straight so its angled downward and isn't going to bottom out to much.. I like it a lot.
Old Jun 4, 2009 | 12:27 PM
any other inputs?? ANYONE!!!!!
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
