Another intercooler question...
Old Jun 25, 2013 | 05:29 PM
2.Slow's Avatar
Question Another intercooler question...
Hello guys, i just had a quick question I'm new to this whole new boosted stuff and i just wanted to ask whats the difference between my stock intercooler and those fancy shorter aluminum ones? I hit a bump and had to get the condensor and apparently now my intercooler changed as well.. why does mine look all "cheap" lol
Old Jun 25, 2013 | 06:07 PM
jvirginillo's Avatar
That is the stock Heat Exchanger. It is a good unit for what it needs to do on an unmodified engine.
A lot of the HE units you are seeing are used in 'series' with the stock unit to add efficiency to the cooling system for the Supercharger/Intake manifold.
You can buy a unit to completely replace the stock unit and not run a secondary unit.
For example I have the stock unit and a 2nd H/E mounted behind the front grill. mine came from a Mercedes AMG which the owner had modded and needed more cooling.
Here is one that replaces the stock unit and provides additional cooling.
ZZPerformance - ZZP Stealth Heat Exchanger #ZZ-STLTHE
If your original unit is toasted then this might be a good option unloess you have access to one from a wrecking yard.
Old Jun 25, 2013 | 06:08 PM
Sox-Fan's Avatar
Got Brakes?
Don't confuse your heat exchanger with an intercooler.
Old Jun 25, 2013 | 06:10 PM
^^^^Good Point!^^^
The Supercharged SS (LSJ) doesn't have an Intercooler. Heat Exchanger Heat Exchanger...........
Old Jun 25, 2013 | 06:14 PM
Sox-Fan's Avatar
Got Brakes?
I could just see him ordering an intercooler from someone, waiting a week for ups to show up with it, opening the box and then Fuuuuuuuuuuuuuuuuuuuu!!!!!!!!!!
Old Jun 25, 2013 | 07:45 PM
2.Slow's Avatar
LMFAO! I knew I would look stupid! But the guy fixing my a/c didn't know what it was and the guy from oriellys either... So I took it upon myself to think it was the inter cooler thanks though!
Old Jun 25, 2013 | 09:09 PM
mrbelvedere's Avatar
the intercooler is the intake manifold
Old Jun 25, 2013 | 10:36 PM
2.Slow's Avatar
Okay so my local auto part dealers dont carry the heat exchanger... besides ZZP does anybody know where i can find it without paying $300+ ??
Old Jun 25, 2013 | 11:16 PM
2.Slow's Avatar
IS the ZZP LSJ S3 Cobalt Heat Exchanger the same thing as the "stealth heat exchanger"? please help
Old Jun 25, 2013 | 11:40 PM
try searching on zzp website
Old Jun 26, 2013 | 02:03 AM
No. The S3 (Stage 3) is an additional H/E to be used in conjunction with your current stock unit.
I believe the only unit which replaces the stock unit is the "Stealth".
You are probably going to pay that much for a stock replacement from a dealer unless you can find one at a wrecker.
Turbo Johnny
Feb 21, 2019 09:41 AM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Sep 27, 2015 08:53 PM
