Any downfall to running a lighter flywheel?
Old Sep 19, 2011 | 07:28 PM
Boosted05's Avatar
I saw this posted in the LSJ mod thread and it made me wonder, what could it really hurt running a lighter flywheel?
I have the Fidanza flywheel in my car now, with the ZZP S2 clutch and it drives like normal for the most part. I have to take off a little higher in first as the clutch is really grabby, and low speeds 1st and 2nd can be jerky at times. Which is to be expected. Am I missing something here that this would be harmful in any way to our cars or transmissions?
Old Sep 20, 2011 | 12:30 PM
megaman311's Avatar
I am not really sure, but from experience, the flywheel removes the harmonics that your engine produces. If I had all the money in the world, when installing a lighter flywheel I would have the clutch, flywheel, and crankshaft balanced together at a machine shop before installation. This would create a perfect balance and would minimize any possible failures do to high harmonics.
Old Sep 20, 2011 | 04:46 PM
SaberD's Avatar
does the LSJ use counterbalance weights on the stock flywheel to externally balance the rotating assembly? the worst thing i can see that will happen is getting a vibration issue.
if the stock flywheel is zero balanced, if you just make sure the clutch assembly is zero balanced, and the flywheel also, there should be no issues.
with a lighter fw, you wont launch as hard, and your shifts probably wont be as hard. Having that extra rotating mass of the stock fw can really help you from a launch or during shifting.
however on a race course, its probably better to have a light one because of the throttle response and increased rpm acceleration for faster rev matching. Engine braking will also be better with a lighter flywheel. not to mention slight weight savings for better handling/braking/accel.
overall, i think the lightweight fw is an upgrade. im installing one on my vette in the spring.
Old Sep 20, 2011 | 10:39 PM
Boosted05's Avatar
I can shift slightly faster with the new FW but i need a clutch rod for this to be perfect, bring my engagement up a little. Either way I have about 3k on this setup and I'm really happy. i would suggest it to everyone!
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
jas09ss
Sep 26, 2015 01:06 PM
