Any problems I may run into?
Tomorrow I should be getting...
ZZP 3" catted downpipe
Replacement IC pump
Larger tensioner pulley
Are there any tips you could give me about installing any of these? Or any common problems I might run into?
Thanks ahead.
Replacement IC pump
Thanks ahead.
Downpipe no its easy as hell make sure its warm and u use pb blaster. Also about the ic pump... The hoses will be hard.to get off cut the inlet hose before the clamp and open the outlet port clamp... Tune it as well..
Real good.. except.... my fans are loud as ****? either my fans or my radiator? Not totally sure which it is.. but it's super loud from like 5 seconds after i start my car until I turn it off..
roth
Sep 26, 2015 12:16 PM
