Anybody running a 2.85" pulley w/out rflash ans injectors??
Old Jun 5, 2006 | 08:57 PM
2006ArrivalBlueSS's Avatar
Question Anybody running a 2.85" pulley w/out rflash ans injectors??
Just wondering 'cause I was told this could harm the engine. I have the 2.85" but I'm reluctant to put it on without a PCM reflash or bigger injectors.
Old Jun 5, 2006 | 09:10 PM
ninja44's Avatar
Not like you ever listen to me but DON'T DO IT YOU'RE ASKING FOR TROUBLE!!!
Old Jun 5, 2006 | 09:15 PM
Shortbus's Avatar
With a 2.8, it would be in your best intrest to get bigger injectors, and a tune/reflash.
Old Jun 5, 2006 | 09:30 PM
CTCOBALTSSS's Avatar
I second that BIG time!
Old Jun 5, 2006 | 09:32 PM
silverSS's Avatar
agreed.
You need a tune and injectors.
Old Jun 6, 2006 | 08:51 AM
Rusty's Avatar
i'm fairly confident that the car won't even run with stock injectors and no tune
Old Jun 6, 2006 | 08:55 AM
distillion's Avatar
ang, all in due time, when yer car is tuned either with the stage 1 kit or hp, youl love it, the boost almost instantaniously hits 100 kpa and starts to build from there eventually hitting 120ish kpa, tis sweet!
but ya with yer stock setup i wouldnt chance it.
Old Jun 6, 2006 | 08:58 AM
3fo893013L's Avatar
uh. I just helped install a 2.9 in pulley on a friends car and he is not having any issues to speak of and his isn't tuned.
Old Jun 6, 2006 | 10:35 AM
*TRIX*'s Avatar
it runs
Old Jun 6, 2006 | 10:42 AM
Baawwwaaaa...you know I always listen to you - big bro!!! I'm just anxious that's all - do you blame me??
Old Jun 6, 2006 | 01:50 PM
NGalaxyTimmyo's Avatar
And what was Bryan running again?
ninja44's Avatar
Briiing me , I fix, I fix goot!
Old Jun 6, 2006 | 01:52 PM
distillion's Avatar
ninjas always got a bag of tricks up his sleeve!
Old Jun 6, 2006 | 02:03 PM
06black's Avatar
BE VERY CAREFULL!!!!
a 2.9 dam near or does max the stock fuel system at times in the rev range.
and even tho a 2.85 isnt that much smaller i would still say that its in your best intrests to get the car staged or tuned with some 42 or 60lbs injecters.
TIMMO-I'm runin a 2.7 soon to jump to a 2.5
Old Jun 6, 2006 | 03:45 PM
Spoony's Avatar
Your best bet is to get a tune for larger injectors first...you'd be running the risk of going lean...and that's not something I'd personally be willing to risk.
Old Jun 6, 2006 | 03:50 PM
Rangerondubz's Avatar
Well with running a smaller pulley and stock injectors u risk detonation, b/c your forcing to much air into the motor and not enough gizas, so u better watch out its quite possible that you could blow your motor like my friend did
Old Jun 6, 2006 | 04:27 PM
cashstacker's Avatar
I have 3 inch so far I have seen no signs of ot running lean but what do yall think?
Old Jun 6, 2006 | 04:46 PM
06black's Avatar
with a 3.0 your fine on the fuel system. close to the limit but ok none the less.
DarrenGC
Dec 24, 2021 01:55 PM
patooyee
Oct 15, 2015 05:11 PM
Builttss
Oct 4, 2015 10:21 AM
roth
Sep 26, 2015 12:16 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
