Anybody running a fuel pressure regulator?
Old Feb 1, 2010 | 04:21 PM
terry11's Avatar
I just bought one and was wondering what the best way to set it up would be.
If you want to post some pictures that would be great, or just briefly explain.
I have a good idea what needs to be done but I'm always looking for the easiest/best way to go about it. Thanks guys!
Old Feb 1, 2010 | 04:32 PM
Frew's Avatar
I know of a couple of members that are, I believe 06blackss
Old Feb 1, 2010 | 04:56 PM
rico's Avatar
click
Old Feb 1, 2010 | 05:00 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you need to run a return line or do like zzp does and eliminate the evap system to use it as a return line. there is an in-tank regulator inside the tank
Old Feb 1, 2010 | 05:01 PM
ls1fbody's Avatar
Haz l33t wheelz.
You would usually run this with a return style fuel system, but you don't have to.
Old Feb 1, 2010 | 06:04 PM
terry11's Avatar
Alright that makes sense. Would I have to eliminate all the stuff in the middle of the evap line, like right there in the engine bay too? Or would that line be good enough just how it is? Does anybody have pictures of this setup?
I was looking to get rid of that line anyways i don't want it being on the throttle body anymore.
Old Feb 1, 2010 | 06:31 PM
qwikredline's Avatar
Ez to say hard to do right. Unless you are revising your fuel system best to leave it alone. If you are revising it, OTTP have a good system and you would save the money for the fuel regulator if you have the right one....
Old Feb 1, 2010 | 06:54 PM
terry11's Avatar
Ok never mind i see what they're doing. It would be nice to figure out how to make it work with the regulator i have and not drop another 200 on their system. I could probably just get the evap fittings from them and use that.
Or would this work... Use the vacuum line that used to be on the boost regulator that comes from the intake manifold, which is now removed, for a few extra pounds of rail pressure on top of the stock one. Or would that mess with the tune?
I could just splice into the main fuel line that runs over the valve cover and mount it on the firewall and extend that vacuum line a little bit.
You could make any regulator work really. They all have an in, out, vacuum port, and adjustor screw. I Just don't feel like running a line all the way back to the tank. I think it can be done without having to be a return style...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
dieGone
Oct 1, 2015 06:27 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
