Anyone Using a Water Injection kit??
Old Oct 13, 2005 | 12:28 AM
c24na's Avatar
Hey Guys,
Is anyone using a water injection kit? What kind of results are u getting? what kit are u using.
Thanks!
Nate
Old Oct 13, 2005 | 12:40 AM
DJNateGnau's Avatar
Hey Nate! My name's Nate too! But, no, I am not using water injection.
Mercury's Avatar
Selfinfliction is.
Old Oct 13, 2005 | 06:35 AM
selfinfliction's Avatar
Originally Posted by c24na
Hey Guys,
Thanks!
Nate
www.ricermath.com/injection.htm
no actual number results and it's not installed right now. i am making plans that when i get a 2.85 pulley put on i am going to put a smaller tensioner(if needed) on and that should give me enough play to put like a 1/2" - 3/4" plate between the blower and engine so i can run the injector on the output side of the blower. this will also allow me to run an alky mix instead of just water.
Old Oct 13, 2005 | 02:16 PM
VaMP's Avatar
But the big question is, are you going to still use it after you get a CIA?
Old Oct 13, 2005 | 07:07 PM
why would i not? running alky/water with or without a cai is going to make more power.
Old Oct 13, 2005 | 07:10 PM
VaMP's Avatar
Yeah but it was easy to put a hole in the plastic intake we come with OEM. Would you be willing to risk $250-$350 to drill a hole in your CIA for water injection?
Old Oct 13, 2005 | 07:46 PM
italstalnprd86's Avatar
what exactly is water injection?? you cant inject water into the manifold, at least i dont think, so im confused, someone throw me a link that explains it or explain how it works to me..... thanks
Old Oct 13, 2005 | 09:00 PM
VaMP's Avatar
selfinfliction already posted a link
Old Oct 13, 2005 | 09:09 PM
Chevypowered's Avatar
summit racing has some good choices for water injection, take a look there
Old Oct 13, 2005 | 10:59 PM
05_Blue_B10WN_SS's Avatar
Water injection cools down the intake air temps, thus makes more power. The water turns into the steam and burnes up in the combustion chamber absorbing heat.
Old Oct 14, 2005 | 09:23 AM
epiphany's Avatar
Ive seen on most setups guys were using one injector after the blower and one injector after the intercooler. But since we are running an air to water intercooler should we just need one after the blower?
Old Oct 14, 2005 | 05:35 PM
i'm getting an adapter plate to fit it between the blower and motor, i'm not tapping into a $250 intake. besides if i go through the intake tube i will be stuck with running straight water, (so i don't f'up the blower blades) and i want to run alky mix
Old Oct 14, 2005 | 05:38 PM
there's alot of options for this stuff. some people run different size nozzles in different places and that's considered a 2 stage kit. each nozzle is set to kick in at different rpm's and such. other people will run straight water before the blower and then straight alky in the second nozzle on the other side of the blower. i'm just trying to keep it simple
Old Oct 14, 2005 | 08:20 PM
97cavie24ls's Avatar
there is a reason they use a boost switch , that way you dont push the spray into the blower unless you need it
the j @ w body guys have been doing it for a long time , with no problems
besides you need to cool the s/c as well as the air , not just the air
not to mention you already have the intercooler to cool the air
nathan112i
Sep 30, 2015 07:12 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
metroplex
Sep 27, 2015 07:48 AM
