ARP Studs
ARP Studs
Hey i was wondering if anyone knows the correct way of installing ARP studs i recently had a blown headgasket and im ordering some of those studs if anyone who has done it could give me some pointers that would be great
if the studs do not install by jand then you need to get a thread chaser and clean the threads up and clean out the bolt holes realy well once the holes are cleaned out apply a light couat of arp lube to the stud screw them in until they bottom out then unscrew them about a 1/8 to 1/4 turn do not torque the head with the stud bottomed out in the block if you do you can pull the threads out of the block
