ARP Studs
Old Apr 24, 2012 | 12:53 PM
Slowbalt4life's Avatar
ARP Studs
Hey i was wondering if anyone knows the correct way of installing ARP studs i recently had a blown headgasket and im ordering some of those studs if anyone who has done it could give me some pointers that would be great
Old Apr 25, 2012 | 11:30 PM
anyone?
Old Apr 25, 2012 | 11:43 PM
conerboner's Avatar
hand tighten the studs into the block and put the head gasket on then the head and then torque the nuts in the right sequence
Old Apr 26, 2012 | 10:44 PM
so when i hand tighten then i dont need to tighten them anymore? once there snug from hand tightening there good?
Old Apr 26, 2012 | 11:09 PM
bluebalt07's Avatar
^Yes
Old Apr 27, 2012 | 12:30 AM
mrbelvedere's Avatar
if the studs do not install by jand then you need to get a thread chaser and clean the threads up and clean out the bolt holes realy well once the holes are cleaned out apply a light couat of arp lube to the stud screw them in until they bottom out then unscrew them about a 1/8 to 1/4 turn do not torque the head with the stud bottomed out in the block if you do you can pull the threads out of the block
Old Apr 27, 2012 | 01:12 PM
so leave some space at the bottom of the block you saying thats why you said unscrew about a quarter turn once there bottomed out?
Old Apr 27, 2012 | 01:55 PM
between 1/8 to a 1/4
Old Apr 27, 2012 | 10:23 PM
okay thanks
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
