ATTN LSJ's!!
Old Jun 21, 2010 | 05:39 PM
  #76
ItalianJoe1's Avatar
Originally Posted by csementuh
My 07' had the old tensioner also. I replaced it a couple weeks ago. It's really a wash as to the cutoff point of the new tensioner. If you are hearing the noise, it's a pretty cheap fix for the piece of mind...
It's not the design they use now (the LNF style one), but i'm sure it was an updated style from the earliest ones. There were subtle changes along the way, but obviously, based on the amount of '07 cars with problems, they never got it right until now.
Old Jun 21, 2010 | 10:09 PM
  #77
Furious_Cobaltss's Avatar
If you give them the right part number it will be the updated one. Or order from crate engine depot or any of the other GM parts websites.
ok thanks.. ill just order order one
Old Jun 24, 2010 | 04:24 AM
  #78
Traviper's Avatar
soo i put it on.....and still making the same sound.
it's when i clutch it to shift it sound like rubbing of some sort, and goes with the rpm's.
Old Jun 24, 2010 | 11:46 AM
  #79
G11's Avatar
G11
wow i think i have this problem...for the last 2 weeks my valve noise has gotten like 2 to 3 times louder and it has been buggin me. I have an 07 as well i guess i will have to check it out and see if i have the old in there as well. Im assuming so tho cuz my car was built in 06 but considered 07
Old Jun 24, 2010 | 11:53 AM
  #80
scotch89's Avatar
ya if you need help give me a call^^^^ its pretty simple. i PMED ya on RME about the header. send me a pic when ya can
Old Jun 24, 2010 | 12:03 PM
  #81
so its a clicking ticking sound....does it sound like a exhaust leak but up by the firewall?
i have a 06 so maybe i need to get one of those bad boys
mine might be a exhaust leak but idk where its leaking haha
Old Jun 24, 2010 | 12:06 PM
  #82
scotch89's Avatar
i thought mine was a exhaust leak, but it kept getting worse. so i did some research and found out it was this. still havent had a problem with mine.
Old Jun 24, 2010 | 04:15 PM
  #83
Traviper's Avatar
thats exactly what mine sounds like
Old Jun 24, 2010 | 11:41 PM
  #84
yea like when im on the throttle and drive pass stuff u can hear the ticking so to me its a small leak
but ill get this part swapped when i get the funds
Old Oct 2, 2010 | 11:12 PM
  #85
SunburstSS's Avatar
Ordered mine today i'll post an update when i get it changed it this week with my oil
Old Oct 3, 2010 | 12:15 AM
  #86
leviticus88's Avatar
I'd say this is a must for any LSJ of any Year. It's $40 and can save your engine, just do it and sleep good at night. The install wasn't that bad, I removed the valve cover and that made it much easier.
Old Oct 3, 2010 | 01:25 AM
  #87
RooTBeeR's Avatar
i did it recently...easy as ****, pull the old one out, put the new one in(tq to 55 lb/ft) and be on ur way
Old Oct 3, 2010 | 02:17 AM
  #88
install mine
Old Oct 3, 2010 | 02:55 AM
  #89
RooTBeeR's Avatar
install mine
y? its easy, do it ur self! lol u live to far i dont want to drive to you
Old Oct 3, 2010 | 05:24 AM
  #90
haha im like a caveman ill just sit there for hours throwing the part at the car and itching my head till its installed
Old Oct 3, 2010 | 12:57 PM
  #91
RooTBeeR's Avatar
lol nice, what about shaun?
Old Oct 3, 2010 | 01:04 PM
  #92
Dr.Balt407's Avatar
exhaust leak, i had the same problem. i had a cracked flex pipe, it sounded like a lawn mower before i did the swap
Old Oct 3, 2010 | 03:14 PM
  #93
maybe haha
yea it was leaking from the top bolt on the downpipe
Old Oct 4, 2010 | 08:17 AM
  #94
DVSk8er's Avatar
if anyone needs one i have a brand new one for $30 plus shipping
Old Oct 9, 2010 | 12:40 PM
  #95
eddi's Avatar
Did the RPMs spike aswell?
So I have heard a slight ticking, but I also have been driving around alot and recently my tach started to jump around 3,500to 5k back down then runs fine is kinda got me worried
Old Oct 9, 2010 | 12:45 PM
  #96
chris88z24's Avatar
The build date on mine is 11/06 and to this date with 53k I have had no problems with the tensioner.
It won't sound like an exhaust leak, it'll sound like a LOUD rattle in the valvetrain or the supercharger coupler.
Old Oct 9, 2010 | 03:49 PM
  #97
ViSiONZ's Avatar
So glad I found out about this! My car would randomly make a weird ticking/rattling noise at idle, not all the time though. Glad there is a fix.
Old Oct 9, 2010 | 04:12 PM
  #98
jonnymerk's Avatar
If it's bad enough it may sound like a lego piece is rattling around somewhere. I add to these post when I see them. I recommend always taking off the valve cover when fixing this issue. so many people don't and that's just lazy.
I took my car in for warranty to fix this and they found other issues. The ended up having to replace a cam that some how hard scaring on it. So this is what can happen if it gets worse. So always a good idea to inspect these things.
Old Oct 9, 2010 | 09:22 PM
  #99
SunburstSS's Avatar
hmmmm so is there a purpose for taking the valve cover off besides checking other internals or it just for conveniece ? Thanks man
Old Oct 9, 2010 | 09:46 PM
  #100
jonnymerk's Avatar
besides convenience or checking for other damage I don't know of any other reason to take of the valve cover.
