ATTN LSJ's!!
Old Jun 17, 2010 | 05:01 PM
  #51
ItalianJoe1's Avatar
no idea on the lash adjusters. i heard they are quite beefier though?
They made new ones? Please tell me they didn't increase the travel... Otherwise I want my GMR cams back
Old Jun 17, 2010 | 06:18 PM
  #52
Frew's Avatar
dude when I pulley the original one out of my head it fell apart in my hand, I looked like steve carrell in 40-year-old virgin when he is at the free clinic and picks up that plastic vagina
the lash adjusters look a little different, its the roller rockers that look beefy, they incorperate a closed roller design
Old Jun 17, 2010 | 06:22 PM
  #53
ralliartist's Avatar
okay, so where to get the new lash adjusters and roller rockers?
Old Jun 17, 2010 | 06:34 PM
  #54
Pyros777's Avatar
We need a whole new thread for "updated uber awesome LSJ parts"
Old Jun 17, 2010 | 06:36 PM
  #55
Frew's Avatar
gmpartsdirect.com thats where I got mine
Old Jun 17, 2010 | 06:41 PM
  #56
Fuuuu....
I wanna build another LSJ
Old Jun 17, 2010 | 06:42 PM
  #57
Frew's Avatar
its been lulz thus far, now give me you damn oil pan faget!!
Old Jun 17, 2010 | 06:43 PM
  #58
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by ItalianJoe1
Fuuuu....
I wouldn't mind a built motor. Go ahead
  #59
BLAZIN07SS's Avatar
I'm too JDM for you
Fuuuu....
i say we put an LSJ in your cavy. just sayin'
Old Jun 17, 2010 | 06:48 PM
  #60
~Mike~'s Avatar
At work so I don't have time to read the whole thread...but I occasionally get a rattle noise that somehwat resembles blower chatter and found it to be coming more from the back side of the engine...same issue possibly? Mines an 07 and I've been told what was stated in the OP...I shouldn't have a timing chain issue since I'm supposed to have a revised version.
Old Jun 17, 2010 | 06:49 PM
  #61
BLAZIN07SS's Avatar
I'm too JDM for you
more than likely the timing chain tensioner. and i was told the same thing
Old Jun 17, 2010 | 07:05 PM
  #62
I agree.
part number? I'm looking on gmpartsdirect right now, and it just has the lifters(lash adjusters) and rocker arms listed as normal. There isn't anything that says revised.
Last edited by ralliartist; Jun 17, 2010 at 07:05 PM. Reason: Automerged Doublepost
Old Jun 17, 2010 | 07:06 PM
  #63
Frew's Avatar
Thats what I order, there was no option or anything for a revised rocker, I dont have any of the bags etc, its all at my storage unit
Old Jun 17, 2010 | 07:17 PM
  #64
ah okay. Just curious, why did you order new rocker arms and lifters anways?
Old Jun 17, 2010 | 09:02 PM
  #65
Wanna pay for it? I'll gladly build motors mail-order.
I want one for myself though. I had fun hurting feelings in a Cobalt for a long time, and that was working against parts that didn't exist and info that wasn't there. With the resources that are out there now... my car would have been incredibly nasty.
I very seriously considered it. Espscially in the 'vert, it would be lulz.
When I had the black '98 shell here, it was calling me. I still had the LSJ trans and all that **** here too.
I did some numbers though, and it would honestly be cheaper to get a plain-jane '05 base balt, and put an LSJ drivetrain in it. Too much stuff needed to be swapped to make the LSJ stuff work in a cavi, and you can find a base cobalt for dirt cheap.
Last edited by ItalianJoe1; Jun 17, 2010 at 09:02 PM. Reason: Automerged Doublepost
Old Jun 17, 2010 | 09:25 PM
  #66
insylem's Avatar
Thumbs up Sticky!!
Sticky!!!
Old Jun 19, 2010 | 08:32 AM
  #67
FastSSinNH's Avatar
Is there a how to on replacing this?
Old Jun 19, 2010 | 08:34 AM
  #68
jimbos'ss's Avatar
i need to get this.
Old Jun 19, 2010 | 09:43 AM
  #69
scotch89's Avatar
3rd page its my how to
Old Jun 19, 2010 | 11:50 AM
  #70
Frew's Avatar
its very easy to replace, but like blazin said, its best if you remove the valve cover to make sure that the tensioner is seated correctly
Old Jun 20, 2010 | 09:38 AM
  #71
FastSSinNH's Avatar
Oh, Thanks buddy
Old Jun 21, 2010 | 05:44 AM
  #72
Omega1x's Avatar
As we all know, there have been issues with timing chain tensioners in our cars failing. However GM stated to have fixed this after the 2006 cars.
This doesn't seem to be the case in my 2007. I had a random rattling noise at idle from time to time. Sounded just like heavy valvetrain noise. Since it was random I chalked it up to the timing chain tensioner.
I also had a little leak from the valve cover gasket right under the intake cam so I decided to buy a new valve cover gasket kit and a new timing chain tensioner from Crate Engine Depot. Corvettespirit, Dr.Balt407 and I made a little discovery as to why you should get the new style chain tensioner. Anyway here is the carnage from an old style 2 piece tensioner.
Yes, that is in 5 pieces and a little clip it has is missing. I also dropped the pan that day and found bits of that clip in the oil pan. If you are having random noise at idle that sounds like valvetrain noise and it comes and goes, this very well could be your issue. Much bigger issues could have came from this and I am glad I changed it.
You can find the part at Crate Engine Depot for like $40 plus shipping: http://www.crateenginedepot.com/stor...P2216C133.aspx.
Hope this helps some of you!
Oh man, thank you for posting this. Me and a buddy have both been wondering what that noise is. Both of ours have intermittent "knocking", usually after a hard pull.I will have to get this dealt with ASAP. Again, thanks for posting.
Old Jun 21, 2010 | 11:25 AM
  #73
csementuh's Avatar
My 07' had the old tensioner also. I replaced it a couple weeks ago. It's really a wash as to the cutoff point of the new tensioner. If you are hearing the noise, it's a pretty cheap fix for the piece of mind...
Old Jun 21, 2010 | 04:35 PM
  #74
Furious_Cobaltss's Avatar
Has anyone got an updated one from the dealer.. I just called and they dont know anything about the upgraded one.. Do i have to order online
Old Jun 21, 2010 | 04:53 PM
  #75
csementuh's Avatar
If you give them the right part number it will be the updated one. Or order from crate engine depot or any of the other GM parts websites.
