Back to Stock Tuning...
Old May 17, 2009 | 02:49 AM
ecotecon18s's Avatar
Hey guys, I'm turning the car back to stock tomorrow, and was gonna try and tweak the stock tune to get the most power I can out of the car safely.
A few things I need to know. On the STOCK injectors and pulley:
-Is it safe to run it lean...like mid 11's?
-Is it safe to run high timing, as long as there is no knock?
-Is it safe to run a higher redline (~7200RPM)...
I'll be using the stock injector table that came on the car.
Old May 17, 2009 | 02:56 AM
steddy2112's Avatar
Mid 11s is not lean...
Old May 17, 2009 | 02:57 AM
EXsoccer1921's Avatar
AIR TO FUEL RATIO
11 parts air to 1 part fuel is not lean.
Old May 17, 2009 | 03:00 AM
Well I've heard once you get into the 12's, that's dangerous territory. I was told that 11.7 is the best area.
Remember...this is on the STOCK injectors, on the STOCK GM injector table...
Old May 17, 2009 | 03:02 AM
well. to answer your question. yes, the car can be tuned stock and you can see a slight increase in power. nothing crazy to write home about. and it probably won't even be noticible to your foot seat of your pants unless you are able to make seperate runs at the track
Old May 17, 2009 | 03:07 AM
I would have to disagree. I've ran multiple diff tunes on the same setup I had, and after playing with timing (the stock table is weak), PE mode AFR and enrichment rate, and upping the redline, I've seen different gains in power in both the power band and on the track.
That's what I'm hoping to accomplish with this...The only performance mod that will be on the car will be a 2.5" Magnaflow catback. No intake, stock header and DP, no meth.
Old May 17, 2009 | 03:09 AM
so if you already know the answer....why make the thread??? i think the most someone would be able to get out of a stock car would be between 10-15whp
Old May 17, 2009 | 03:14 AM
I just wanted to know if the stock injectors could handle a higher redline than the stock 6500 and the higher timing. I have 60's in the car right now, but they are coming out tomorrow. I guess since I'll be back on the stock pulley, i should be able to run more timing and the higher redline with no problems. Guess I'll find out tomorrow...
And yeah, it probably wouldn't be much more than 10-15hp, atleast not without other mods. Most all the other stuff I had has been sold off the car, or taken off to be sold.
Turbo Johnny
Feb 21, 2019 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
How to Guide
57
Oct 15, 2015 11:56 AM
kzak104
Oct 11, 2015 05:19 PM
camaromanss1992
Oct 1, 2015 10:51 PM
