bad mab header install
Old Dec 22, 2011 | 11:29 AM
sick CCSS's Avatar
just installed the bad mab header on the car lastnight, wasnt very hard, just took alot of time since the bolts are a pita to get to. had the car out today since the roads are pretty good and everything seems good, but i was just wondering if i should install the heat sheild, or if it will be ok without, personally i dont wanna put it back on, but i dont wanna melt or burn anything. thanks guys.
Old Dec 22, 2011 | 11:36 AM
padlock's Avatar
no you dont need it
i dont even think you can put it on as one of the bolts for it is suppose to connect to the stock manifold, which you now dont have
Staged07SS's Avatar
Administrator
Administrator
You wont be able to install the heat shield.
It is fine with out it.
Old Dec 22, 2011 | 11:37 AM
^ what that guy said
Old Dec 22, 2011 | 11:41 AM
sick CCSS's Avatar
ok just checking guys thanks, it will fit as some said it may take some bending, but it wilo nly be held on by 2 of the 3 bolts, the 1 bolts to the manafold, the others bolt to the motor. no biggie, ill let it off.
Old Dec 22, 2011 | 02:29 PM
Staged07SS's Avatar
Administrator
Administrator
Yeah, it would prob rattle like hell.
Just leave it off
Old Dec 22, 2011 | 05:20 PM
574's Avatar
574
let me know what you think of the header. I want to get it but I have heard some mixed feelings about it
Old Dec 22, 2011 | 06:09 PM
scoobydoobie's Avatar
I've had mine on a couple weeks now. I love it. Sounds good and no leaks. Butt dyno says it's great. LOL
Old Dec 22, 2011 | 06:37 PM
HOTFISH47's Avatar
I have a bad mab header and i like it alot, also have a zzp catless downpipe and a resonator. sounds pretty good to me.
Old Dec 22, 2011 | 08:15 PM
574's Avatar
574
You guys use the gaskets that come with it?
Old Dec 22, 2011 | 09:10 PM
sick CCSS's Avatar
i used the gaskets that came with the header, and yes so far the header is awesome!!!
Old Dec 22, 2011 | 11:28 PM
klloyd's Avatar
I have had mine since february and I am happy with it. I used the header to head gasket that came with it but I put a GM gasket where it bols up to my ZZP downpipe. I never had good luck with those foil gaskets holding up so I just chucked that one.
Old Dec 23, 2011 | 11:48 AM
Staged07SS's Avatar
Administrator
Administrator
Same here.
Old Dec 23, 2011 | 01:08 PM
chevygirl2006's Avatar
My header will be delivered today. Did u put urs on a lift or did u just do it on the ground?
Old Dec 23, 2011 | 03:52 PM
sick CCSS's Avatar
i just used 4 jack stands and threw a nice soft bed blanket down lol. make sure you got the car up off the ground a ways.
Old Dec 24, 2011 | 12:35 AM
I helped a friend do a badmab and zzp catless downpipe today.. 2.75 cat back with no resonator and magnaflow muffler. Man that thing is loud.. lol
Old Jan 17, 2012 | 08:39 PM
bobbyjohn681's Avatar
im new to the SS scene, if i run a bad mab header, can i go with the 3" zzp DP w/ 2.5" tail flange and and ark grip catback?, i know the catback is 2.5", but i hear alot of members going for the bad mab shortie and not sure if the zzp DP will bolt to the bad mab without any problems, the catback is designed for oe dp they say
Old Jan 17, 2012 | 09:05 PM
Import Reaper's Avatar
yes it bolts up fine from header to DP
Old Jan 17, 2012 | 09:07 PM
advise's Avatar
Yup that down pipe will bolt right up
Old Jan 17, 2012 | 09:18 PM
and the dp is made to bolt to stock catback w/ 2.5 exit right?
Old Jan 17, 2012 | 09:31 PM
just dont get this set up if u r a 2.4 ....zzp 2.5 catted downpipe, badmab header, pacesetter catback
sounds horrible
Old Jan 17, 2012 | 09:34 PM
heathkidder's Avatar
Add a glass pack and it wont
Old Jan 17, 2012 | 09:38 PM
glasspacks sound terrible.
im going with a resonator eventually
Last edited by chevygirl2006; Jan 17, 2012 at 09:38 PM. Reason: Automerged Doublepost
Old Jan 17, 2012 | 10:15 PM
its a lsj, **** a le5 lol
Old Jan 17, 2012 | 10:22 PM
i love my car but whatever
