Bang for my Buck?
Bang for my Buck?
I have an 07 SS/SC with 2000 dollars after working alot of over time. Can anyone give me a list of mods for around 2000 that would get me the most performance? I realy need some opinions on this thank you!
Is warranty a concern for you? If so:
Stage 2, GMPP Catback exhaust, Ingalls, intake if you want to go that route
Take a look at my numbers/dyno sheet and the dyno video I have linked in my sig. to get an idea of where my mod list put me, then price it out. Do the same with kenhebe's.
a little over $1850 will get you GMPP stage2(installed),GMPP manifold, GMPP performance cat-back and exhaust tip(not installed), intercooler end plate and surge tank, GMPP 2.9 pulley, and Intense-Racing suspension pkg(polyurethane Control Arm Bushings/Tranny mount inserts) These mods would make your Cobalt about the best it could be while still under warranty I'm guessing you would be around 260-265whp
are these #'s what you get with a stock 'balt? If so a staged Cobalt should yield slightly higher gains...
Last edited by BLKblurr06; Mar 25, 2007 at 11:43 PM. Reason: Automerged Doublepost
No the Stage 2 is a 3.0" pulley(77.9mm) why would gm include the same pulley in stage 3 as in stage 2 when you need stage2 in order to install stage3? stage 3 pulley is 2.9"(76mm) check crate engine depot link>>>
stage 2 pulley listed in kit description
http://www.crateenginedepot.com/stor...9-P1540C0.aspx
stage 3 pulley
http://www.crateenginedepot.com/stor...P1749C196.aspx
Stage 3 is 76mm which is ~2.99"(http://www.google.com/search?hl=en&q...in&btnG=Search)
Stage 2 is 77.9mm which is ~3.06 (http://www.google.com/search?hl=en&q...in&btnG=Search)
My bad on the stage 2, I guess I was rounding a bit too much.
Cptnslo
Sep 24, 2015 09:32 AM
